Chevy nut
No factory rear view mirror?
When I got my 69 stepper...it had like a 40's style car rear view mirror in it. When I took the screws out of it...I noticed that there were no screw holes for the original mirror. Anyone ever heard or seen mirror delete?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Active Member
![]() Join Date: Jul 2007
Re: No factory rear view mirror?
Does it even have indentations where it mounts?
In the old days these trucks could be ordered with or without just about any options, but I've never seen one without a rear view mirror. Also, didn't the 72's have the mirror on the windshield? If that's the case, maybe someone swapped cabs... |
Chevy nut
This is the original cab. The guy that my brother got it from got it from the original owner. I called the guy and he said when he got it...it had on rear veiw mirror in it. He had it from 93 to 98 when my brother got it. No markings for the mirror to be drilled. I had to measure and center and level before I drilled the center hole.
My K-20 was a State Highway Dept. truck and had no inside mirror. Had the radio delete as well.
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Barrito Loco Diablo
My 72' has the mirror mounted on the windshield. I've looked it up to make sure it's the correct mirror, because the visor on the driver side hits the mirror when i try to put it down. I'd ditch it, if i didn't use it. Plus, i'm running it without side mirrors currently, so, i need something. But yeah, they were mounted on the windshield.
Barrito Loco Diablo
Wait, can you get a pic of the mirror? i'd like to see whatcha got. Maybe it's something rare.
i have a 69 swb 4wd...came with 292 six, a huge 3spd (much larger than my 72K5) a rockwell T-221 transfer case and as i began to pull it apart the original paint appears to be army green/forest truck green...it has no rear view mirror or any type of mounting spot for it....i have wondered about this too...Edited by Moderatorthanks...scott
Roadtrip!
![]() Join Date: Feb 2003
I believe the rear view mirror was an option thru 69, then standard in 70. Someone correct me if i'm wrong.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Need a bigger hammer..
My 68 didn't have a mirror either and no holes or anything for the mounting of one. I wanted one so I mounted a laterstyle one to the windshield..
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
![]() Join Date: Aug 2004
I have a 69 that is original with no rearview mirror, no radio, no ciggarett liter, and no armrests. John
Nothing to see here.....
![]() Join Date: Jun 2007
yep. optional on '69s
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#12 | |
Gone to greener pastures
![]() Join Date: May 2007
BTW, my '69 has a "ceiling" mounted mirror.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#13 |
its all about the +6 inches
67 - 69 had no mirror as base equopment. If opted with a mirror, it was mounted to the ceiling. Many were sold as a dealer add on when the buyer ordered a truck and upon pickup, had no mirror. This explains older style mirrors (67/68 style) mounted on 67 - 69.
In 70, they became standard, but still mounted on the cab ceiling. In 71, they incorporated a raised mounting point on the cab ceiling to mount the mirror. In 72, it was moved down to the glass where it could fall off and GM could sell you a replacement. |
#14 |
Chevy nut
Man Andy, Your a Chevy truck manual today! All the replies I have seen you post today...I am getting educated by reading your posts! Good job Andy!
#15 |
Barrito Loco Diablo
Maybe just another shorter head mount will do.
#16 |
camino... this very question was the second question i asked when i signed up. A former member educated me, and then i searched and found the rest of the story.
In all reality, now that I think about it... I think there was one year in 67 - 69, where the inside one was base equipment. None the less... my second truck was a 69 GMC short/fleet 1500, had a 67/68 style mirror, and it wasn't centered properly. My first truck was a 70, and I figured they were all like that 70 was. So I asked and learned. |
#17 | |
Chevy nut
So Andy...and the rest of you guys...thank you for being here to educate the rest of us here. (yes at 40 you can still learn something! ![]()
#18 |
Option was arm rests? Wow. Didn't know that one either.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#19 |
ok... answer me this...
is an el camino a car... or a truck? ![]() |
#20 |
YES!
#21 |
lol!
#22 |
My 68 C20 had no inside also, but had two round mirrors outside. Belonged to a city before me.
#23 | |
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
#24 |
Barrito Loco Diablo
It's a car/truck. I had a 79' with a 305. used to ride around town sitting on a milk crate cuz i had no seats. True pimpin'.
I noticed the arm rests in the 72' are basically useless as an armrest while driving. It's way too low, unless i sit funny. I use it to shut the door. I decided to use the mirrors off my 61' Triumph for side mirrors on the truck. Clamp em up on the doors like the clamp on style ones. |
