Old 07-06-2008, 07:47 PM   #1
jdfrmnt
6 lug rotor change over
i just picked up a 85 1500 and was woundering if i could use the spindels and newer rotors that are 6 lug
jdfrmnt is offline   Reply With Quote
Old 07-07-2008, 06:19 PM   #2
68burb
Re: 6 lug rotor change over
an 85 would have 5 lugs or 6 if it was 4x4.
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 07-07-2008, 06:19 PM   #3
JMurray
If its just a parts vehicle just yank the whole front end out and do a swap! If your just wondering if you can use the 85 spindles and rotors and that it the answer is no!
Clarify exactly what you are wanting to do
JMurray is offline   Reply With Quote
Old 07-07-2008, 08:37 PM   #4
jdfrmnt
what i wanted to know is can i use the control arn spindles frome the 85 and use newer rotors that are 6 lug
Old 07-14-2008, 08:43 PM   #5
manimal
manimal's Avatar
If you are wanting 6lugs visit the vendors sites(Brothers or ECE any many others) and get a set of 6lug rotors(designed for the earlier 6lug trucks using 71-up disc brake spindles) for your truck. You cannot use the NEW style rotors on square body trucks.I have been toying with this idea for a while now. Use 6 lugs all the way around on my '84 crewcab. I would either use a 4x4 rear 12blt or 6 lug semi float 14bolt.Good luck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
