07-09-2008, 12:02 AM | #1 |
Windy Corner of a Dirty Street
8.1L install into 1978 K10…DONE
Well, I am excited as all hell to finally have this never ending project coming to an end and the electrical section doesn’t get much action so I figured I would share these videos here as well.
I still have some fine tuning that needs to be done to the engine controller but all in all it runs very well on the initial start up. The tuner claims over 400 HP and over 400 lb ft of torque from a stock 8.1L running on a MEFI-4 controller and from what I can tell so far….it feels like they might be right! It has some major gonads! The audio quality is pretty bad on my camera but you get the idea.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
07-09-2008, 12:14 AM | #2 |
Re: 8.1L install into 1978 K10…DONE
Sounds awesome! There's just nothing like raw cubic inches!
1977 GMC Sierra Grande |
07-09-2008, 01:06 AM | #3 |
very nice... is it just the angle of the shot or is the engine leaning a little towards the driver's side?
02 Chevy 2500HD D/A EC SB 4x4 MA SCIII trans, EFI Live, 5" exhaust, 5% tint... 83 GMC K30 Crew Cab Short Bed 06 Duramax & ZF6 (to be installed) and more to come... |
07-09-2008, 03:50 AM | #4 |
THE VILLIAGE IDIOT
sweet.. sounds good
honestly honey,,i have no idea how that truck got here. |
07-09-2008, 08:55 AM | #5 |
Must be the angle of the shot as there is no engine lean.
07-09-2008, 05:37 PM | #6 |
awesome congrats
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
07-09-2008, 06:15 PM | #7 |
What Hump?
Very nice, everyone came running into the room to see what was making the noise. Awesome job!!!!!
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
07-09-2008, 07:01 PM | #8 |
Fix It Till It's Broke
Looks awesome man and sounds even better
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
07-09-2008, 07:39 PM | #9 |
Thanks guys… Here are a few pictures of the final install.
I have a buddy coming over tonight to help lift the hood back on then need to charge the A/C this weekend. It runs well enough to drive around to shake out the bugs but there is definitely fine calibration tuning to be done to address cold start issues and wide open throttle performance as well as a some underhood wiring clean up to be done. Also have an issue where the dual fuel tank switch valve causes a restriction on the return side causing the fuel pressure to run around 100 psi so the Pollak tank switch valve is bypassed at the moment until I figure out how I want to deal with that issue. Probably go with a transfer pump to transfer fuel from the LH tank to the RH tank on the fly as there appears to be no fuel tank switch valve with a 3/8 return line.
07-09-2008, 08:03 PM | #10 |
Dually Pride
Very nice, looks awesome!
So any details on the motor? Is it just stock or have you done anything to it? Or plans to do something with it?
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
07-09-2008, 10:31 PM | #11 |
It followed me home?
SEXY!!!!!!!!!!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-09-2008, 11:50 PM | #12 |
Very cool, I want soooo bad to do a duramax swap into a 4x4 blazer.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
07-09-2008, 11:57 PM | #13 |
Nice! I have that engine in my 2500hd. Did you get a programmer for it. I would like to get more out of my truck.
07-10-2008, 09:27 AM | #14 |
Low & Fast!
That is cool!!!
07-10-2008, 12:02 PM | #15 |
74 C-30, drbyrdman,
The engine is bone stock running a marine type Delphi MEFI-4 engine controller with tweaked marine calibrations. 420 HP and 490 to 505 lb ft of torque (similar to Marine) will be plenty for this rig so no other performance mods are in the plans. (Although, I have another 8.1L that will eventually find its way into my 68’ GMC that will get the go faster treatment) This is the same engine that is in my stock Silverado 2500HD but the production vehicle PCM-32 engine controllers are constrained by emissions controls and torque management that only yield 340 HP and 455 lf ft of torque. You can tune the PCM-32 controllers to produce a lot more HP but I prefer the MEFI-4 route as the harness is less intrusive, the engine controller can be mounted right on the engine, and it runs OBD1 rather than OBD2. You can actually feel a major difference in power between the Silverado and this truck. The Silverado is pretty slow but will pull down a house. The K10 is actually pretty fast and feels like it will pull down 2 houses (scary with a rear Detroit locker!) even though it still needs the fine tuning calibrations done.
07-10-2008, 02:33 PM | #16 |
That is flatout BADASS!
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
07-10-2008, 06:36 PM | #17 |
TOTALLY AWWESOME!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
07-10-2008, 07:03 PM | #18 |
1962 C-10
Siiiicckkk!!!!!!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
07-10-2008, 07:16 PM | #19 |
Definitely something different than the common 5.3L and 6.0L swap. What is nice about the 8.1L is it is direct bolt in. I used my existing 454 exhaust manifolds, engine mounts and even Centerforce clutch and pressure plate that was originally on my 350 then later on the 454HO. No need to fiddle around with changing engine mounts, plumbing new exhaust and dealing with an A/C compressor that is shoved down in the frame rail like the 5.3L and 6.0L requires….the 8.1L is definitely an easy swap in my opinion. More powerful too in stock form.
07-10-2008, 07:33 PM | #20 |
Flippin Sweet!
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
07-10-2008, 07:59 PM | #21 |
Sophomore Member
that's sweet, i had that same based engine in a boat i had. ran like hell. look at raylar for performance goodies.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
07-10-2008, 08:58 PM | #22 |
can i put a marine controller in my 2002 2500hd??
07-11-2008, 10:05 AM | #23 |
Physically, yes….with a wiring harness change. You would lose the use of cruise control and a few other things so it would not be worth it. You can always have your stock Silverado engine controller reprogrammed to gain additional HP...probably not as much as the marine HP numbers as the Silverado still runs OBDII and needs to be emissions compliant.
09-16-2012, 12:33 PM | #24 |
Larry-
Do you have a "build thread" for this swap? Really been considering pulling the trigger on this swap for my dually. |
09-16-2012, 01:09 PM | #25 | |
Here is a great thread on an 8.1L swap into a 1ton 2wd dually by another member.
