09-28-2008, 12:10 AM | #1 |
track times with ls1
I made it to the track finnally.
Ran 3 back to back 1/4 mile passes. all 3 were 12.41 at 106.5, my 60ft was a soft 1.85. I would take some more pics of the truck but my wifes camera died. There is some on the board somewhere though. Engine is a 6.0L iron block, L92 heads, and thorley headers. I copied the 6.0L that carcraft did. I just used a proform 750 instead of a 850. Transmission is a turbo 350 with a PTC street fighter convertor, it needs to be looser. Rear gear is a 3.73 (needs lower gear) and a 315/60 drag radial. |
09-28-2008, 09:35 AM | #2 |
Registered Truck Offender
Re: track times with ls1
That's looking good. What happend in the first 60' will compound down track,, so I see closer to 12.oh's in your future once you get it hooking.
Good job.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-28-2008, 12:37 PM | #3 |
That's very impressive with the soft 60ft. I went almost that 60ft with a 13.554 1/4 in my old 71 street truck on a 28.5 12.5 Sportsman Pro
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
09-29-2008, 08:33 AM | #4 |
Thanks,
I know it would pick up alot with more gear or higher stall. I am still tuning on the carb right now. |
09-29-2008, 08:29 PM | #5 |
First time at the track, my truck bested a 12.44@110mph with a 1.87 60'. This was 3,900lbs with me in it (57/43 weight bias), 3.73 gears, 26" tire and a 3,200 rpm stall. You have a few more cubes than me starting with a 6.0 block, but I would bet you have more weight as well it being an iron block.
Dropping down to 3,840 (53/47 weight bias), going to a 4,400 verter (flashes to 4,900), running a 30" tall tire, adding a crank pulley and adjusting the tune slightly I ran the numbers in my sig. You definately have more in it. What size verter is in it now? What about weight? Also, how is your tune?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
09-29-2008, 08:35 PM | #6 |
Also, curious to know what the part number is on the headers you bought.
09-29-2008, 11:55 PM | #7 | |
I have an idea on weight, probably 3900 with me. I have not weighed it yet the scales at the track were not working. I tried the timing from 32-36 and it still ran the same. The air/fuel ratio was 12.2 at the track, also it didn't act right transitioning to wot. I have been working on that tonight and have it figured out. |
09-29-2008, 11:57 PM | #8 | |
I will have to try and find the part #. Last edited by 1FAST68; 09-29-2008 at 11:58 PM. Reason: forgot something |
09-30-2008, 12:00 AM | #9 |
I have some new pics if someone wants to resize them so they will post.
09-30-2008, 06:18 AM | #10 | |
send them to me ktolliver@montgomeryal.gov
09-30-2008, 09:52 AM | #11 |
emailed you 2 pics
thanks for posting them. |
09-30-2008, 09:56 AM | #12 |
your email said it was classified spam..delivery failure...LOL
I couldn't send it to you. |
09-30-2008, 05:14 PM | #13 |
09-30-2008, 08:41 PM | #14 |
here ya go.
09-30-2008, 09:02 PM | #15 |
looks sick!
Hoping to have my 6.0 on the road Thursday! Those times are pretty good
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
10-01-2008, 06:28 PM | #16 |
www.73-87chevytrucks.com
Should be thy324y-c for the 67-72's. Jamie posted the info here and posted a board price also.
http://67-72chevytrucks.com/vboard/s...d.php?t=287231
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
11-26-2008, 12:39 AM | #17 |
Updated..
I worked on the tuneup,,jetting and pumpshots. 1.81 60ft 12.24 at 108mph. I have not taken the powersteering loose or waterpump, also have full exhaust. I now have some better mufflers for it. I sent my convertor off to PTC to get it loosened up 500, maybe that will help the most to get it in the 11's.. Anybody know how much a electric water pump will help? |
11-26-2008, 01:19 AM | #18 |
Improvements are good. Any idea where your making peak TQ? you might be better with a 4,400 verter.
11-26-2008, 01:19 AM | #19 |
Electric Water pump may give you 12-15HP @6000+
Love the truck
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. Last edited by ripdog28; 11-26-2008 at 01:20 AM. |
11-26-2008, 01:26 AM | #20 | |
I did weigh it. With me in it, it weighs 3800 on the dot. |
11-26-2008, 01:27 AM | #21 |
11-26-2008, 03:18 AM | #22 |
Are you looking for a street or race pump? I have two Mezeires, one street and one race. Been thinking about selling the race one but I probably should keep it for the car.
I'd say go with the 4,400 verter. Going from a 3,200 to a 4,400 (flashes to 4,900 at the track) I dropped a solid .2 in my 60'.
11-26-2008, 09:33 AM | #23 | |
I want the street pump, I am eventually going to put heat and a/c in the truck, plus I need to keep the powersteering. If I could just drop a .1 on 60' I think it would run 11's. How far does yours drop back on the shift change? |
11-26-2008, 01:20 PM | #24 |
The old converter was about 2k rpm. This one is about 1,600 rpm.
11-27-2008, 02:34 AM | #25 |
Mine drops from 7k to 5000 on the shift change.
