Old 09-29-2008, 07:51 PM   #1
tool_zeppelin
5 speed tranny for 235?
I'm builing my dad a truck and I'm trying to find a 5 speed transmission that can either bolt on or be adapted to fit a 235 inline 6 cyl. The truck is a hybrid 1950 and 1952 Chevy half ton with the best parts taken from each. He really wants to keep the 235 since he had a truck with the same engine when he was younger. I want to upgrade the tranny for him though and would appreciate any feedback on which tranny would work best. I'm also not against a solid 4 speed, just anything to ditch the 3 on the tree! Thanks.
tool_zeppelin is offline   Reply With Quote
Old 09-29-2008, 08:06 PM   #2
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Re: 5 speed tranny for 235?
S-10.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 09-29-2008, 08:08 PM   #3
tool_zeppelin
any specific year? is it a bolt on? or do i need to find an adaptor?
Old 09-29-2008, 08:22 PM   #4
hounddogs!
hounddogs!'s Avatar
I'll get the scoop from a co-worker that just did this on his '55. I'd bet someone has a build thread on this topic somewhere.
DD '09 Pilot
Old 09-30-2008, 07:22 AM   #5
entourageguy
Yellow truck club
entourageguy's Avatar
Welcome
might want to check out at stovebolt. They can help as well.
We like pictures.
http://www.stovebolt.com/
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-30-2008, 03:30 PM   #6
solidaxel
solidaxel's Avatar
I have a 53 Chevy with the I-6 and it has a Saginaw 4 speed which works great..............but you will need to cut or remove the bench seat as the shifter is located back into the seat area. The truck has buckets seats which cured that problem. You will also need to change the driveshaft to a open drive line which will work better with a new rear end, Camaro, Nova, Monte Carlo etc.. I also have a 55 1st series that I had a Saginaw 3 speed which was a better fit as the linkage was far enough forward that I did not have trouble with the seat and I already had a open driveline so that was not a problem. I think the mounting surfaces for the transmission are the same, someone correct me!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-30-2008, 03:55 PM   #7
70rs/ss
70rs/ss's Avatar
Watching this since I have two 235's. Looking at the rear bellhousing flange on the 235's I'd guess a NV 3500 would work from any 90's 1/2 ton trucks, a T5 from the S-10 or even a camaro, and the trans will use the 235 bell housing from the current 3 on the tree, and finally a muncie or saginaw 4-speed will work as well. There is a company out there that has manufactured an OD 4th gear for the muncie to run a .89:1 ratio (not as much of an OD as the NV3500/t5/700r4) but better than 1:1 as it would be in 4th.
70rs/ss is offline   Reply With Quote
Old 09-30-2008, 04:14 PM   #8
70rs/ss
70rs/ss's Avatar
Stovebolt's site has some info, doesn't seem too hard, but as mentioned if you have the tube type driveshaft cover (original rear, drivetrain) then you need to do the rear end swap, and the alignment dowels may need tweaking to get the alignment right, but should be fairly easy.
Old 09-30-2008, 04:54 PM   #9
hounddogs!
hounddogs!'s Avatar
Info that I got from a co-worker who just did his. Direct bolt-in. His trans is from an '84 S10; up to 87 or 88 would work as well. Somewhere in the late 80s, they went from the mechanical speedo to electronic, so watch that. He also did a cool adapter on top of the box that moved the shifter pivot point and shortened up the throws.
Here is a link that gives alot of info on the T5 swap.
http://www.vanpeltsales.com/FH_web/t5_fivespeed.htm
But like I said, all I had to do was change the friction plate, not the driven plate and the throwout bearing like some of describe.
Another good source is Dave Moore ( Dmoore5356@aol.com ). He is the tech guy for Jim Carter parts. He has done several of these swaps.
DD '09 Pilot
Old 09-30-2008, 09:14 PM   #10
55dude
55dude's Avatar
their is tons of info www.chevytalk.com, the hamb website, use the search function and post some pic's of your project.
55dude is offline   Reply With Quote
Old 10-03-2008, 06:38 AM   #11
scregan
Try these sites. They should tell you more than you would ever want to know.
http://www.jalopyjournal.com/forum/s...d.php?t=171291
http://www.jalopyjournal.com/forum/s...d.php?t=108634
http://www.inliners.org/Jack/t5_page.html
scregan is offline   Reply With Quote
