10-24-2008, 03:18 PM | #1 |
fuel cap loose message
my 05 silverado z71 with the 5.3.only has 24k miles and no noticeable loss of power or fuel milage. lately it's displayed the message "fuel cap loose".or something similar i can't remember the exact wording.it's done it twice,both times just a few minutes after leaving the house.and both times i checked it.it was tight.now,after the latest episode the check engine light came on steady.of course the truck went off warranty earlier this summer.as i'm not able to get it somewhere to get the code read for a few day's,i was wondering if anyone has had a similar expeirence?
" Never look up a dead dogs butt." Last edited by boatpuller; 10-24-2008 at 03:21 PM. |
10-24-2008, 04:47 PM | #2 |
Re: fuel cap loose message
I think you'll find any car since OBDII sets an error code/warning message if it's loose. Are you turning gas cap past tight so it "clicks". If yes, then it's probably failing. If you have a friendly local inspection station they might check the cap for you to tell you if it is losing pressure.
10-24-2008, 04:55 PM | #3 | |
" Never look up a dead dogs butt." |
10-24-2008, 08:26 PM | #4 |
buy a new cap
if the loose light is on and its tight then it, of most things will be that and they are cheap
Travis
travis_moffatt@hotmail.com 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
10-25-2008, 05:09 PM | #5 |
sounds like its time for a new cap. i bet your code is
evap emission control system leak (gross leak detected)
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-25-2008, 09:14 PM | #6 |
Our 2006 Impala kept getting the same message and it was not the cap. Some solenoid vent valve had to be replaced. They did a "smoke check" to find the leak.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 10-25-2008 at 09:14 PM. |
10-26-2008, 02:13 PM | #7 |
yeah there is vent solenoid on the top of the gas cap
10-26-2008, 10:06 PM | #8 |
well,i went and bought a new cap.check engine light went off within about 5 mile's after.we drove about a 150 mile's round trip down to seaside,oregon.check engine light never came back on so,i'm keepin the ole fingers crossed.it almost seem's too simple to be true.i usually don't have that kinda luck.normally turn's into a 500 buck show.
10-27-2008, 07:45 AM | #9 |
My 03 Yukon threw the check engine light for the evap code. When I had gotten gas, the cap felt as tight as it would go, but it had gotten hung up on the strap that keeps the cap from getting lost. Not being used to owning something this knew, I didn't even think about not hearing the clicks...Now I make absolutely sure I actually listen for the clicks
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King |
