14.1 @ 96MPH
Headlight Relay wiring?
I've seen this referenced a few times, using a relay to switch the headlights so as to get them full battery power...what relay(s) do I need for my GMC and how should I wire them up?
Just wondering, since this is probably a better (and more legally safe, heh) idea than wiring up all four to be low/highs. I do a LOT of my driving at night, so I do want as much light as I can realistically get.
Project1970 - LS1 Swap Complete! ![]() |
Here's a wiring diagram with a bosch relay. This is the generic relay you can buy at any parts store for less than 10 bucks. It's a 30A relay which will be more than addiquate for the 12amps max your current headlights pull.
The toggle switch will now be your headlight switch. Take the wire going to your right headlight (mount the relay closest to the battery if you want so you reduce the amount of wiring you need). Be safe and add a inline fuse between the battery and the relay. NOTE: You will use the top image (Switch with power on). Pole connection: 86 - Ground 85 - old headlight wire output 30 - Battery w/fuse 87 - Headlight (Left) 87a - Headlight (Right) ![]() Last edited by Piston; 11-24-2002 at 10:37 PM. |
its all about the +6 inches
Woo hooo....I been planning on this too, but was unsure of the wireing. Thanks.
English Chevy Owner
As I'm a bit of an idiot when it comes to wiring diagrams, what colour is the original wire into the headlight?
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
how much difference does it make if your running wagner halogen headlights.
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers daily driver other trucks 1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel |
GYRO GEARLOOSE
this moght help
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
Seņor Member
You can do this while retaining your original headlight switch. Just catch the two 'outbound' wires... the ones going to the high and low beams. They may be green and tan (that's their colors on newer GM... I'm not in front of a truck to look to verify right now).
Just cut these wires in two and use 2 relays. green (from switch) to pin 86 green (to headlight) to pin 87 ground to pin 85 B+ (fused!!!) to 30 do the same on the second relay with the tan wire (or whatever color it turns out to be). This will give you full headlight switch functionality and full current to the lights. BTW, I realize auto parts stores hawk Bosch relays (or cheapie knockoffs) for upwards of $10 but you should be able to pick them up for less than half that from a nice installer at a stereo store. They cost @$2.00 each in medium quantities, and I used to get them for $1.50 in 100 lot. Bosch is the "standard" but Potter & Brumfeld look the same, are just as reliable, and are reated at 40 amps (Bosch is rated at 30)... even though you'll be pulling less with your headlights. Kenneth
Seņor Member
Just as an update, I did verify the wire colors--
light green = high beam tan = low beam med. blue = B+ coming from dash switch So, if you want to use your factory switch and get plenty of current to your headlights, grab the wires between the floor kick switch and the fuse box (they're in a nice little bundle all by themselves), and do the relays as I described above. I've also started to (slowly) create some wiring diagrams for such things and will be posting them on my site. Here's the first quickie I did of the floor kick switch. Nothing fancy yet. Kenneth
Instead of tapping into it there inside the cab, you would be better off doing it up by the headlamps themselves. This way, there would be less full voltage wire to lose power in.
I plan on mounting mine under the battery tray on the drivers side. (I have daul batterys in the Longhorn) |
#10 | |
Seņor Member
Kenneth
Hmmm, good point on the weather thing...maybe I should rethink my mental schematics.
poker face
One thing that might help is to replace the headlights you have with good quality ones from Hella. The cut of the lense has a lot to do with how much light gets to the ground in front of you. You can also get large round headlights with the removable halogen bulb similar to new cars molded headlights. With the Hellas and some high wattage bulbs (100w high/ 55w low) and relays you will see a lot of improvement.
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month. |
#13 |
how much improvement with stock headlamps.............
#14 |
Well, by stock headlamps, lets just asume you have normal halogon lamps...most do. (my GMC only has one non-halogon)
The diffirance is considerable...just get in a newer car that still has the sealed beam lamps....The camaro of a few years ago...S-10 of a few years ago. It really is quite a bit. At night you can always tell an old vehicle coming up the roat towards you, becouse the headlights are yellow...even orange. They will glow white with this upgrade. |
