Old 11-03-2008, 05:10 PM   #1
dfosh
99 Silverado brakes
I am going to change the brake pads . Is their anything i need to do diffrent because of the anti loc brakes . if so please explain . thanks
dfosh is offline   Reply With Quote
Old 11-03-2008, 09:53 PM   #2
mothertrucker424
mothertrucker424's Avatar
Re: 99 Silverado brakes
open bleeder screws to colapse calipers so fluid doesn,t get push back through abs pump
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 11-06-2008, 12:07 AM   #3
rubrhammer
not necessary. Just retract the pistons with a clamp or big channel locks. I do it every day at the shop with no problems.
Here is a link to a thred I did on PM for GM truck brakes. Youcan use this info (with pics) to do your brake job. Hope it helps you. There are some tips in there to keep you brakes working freely. It shows the rear brakes but the tronts are similar enough that the info applies there also.
Bob
http://www.outbackers.com/forums/ind...opic=23002&hl=
rubrhammer is offline   Reply With Quote
Old 11-08-2008, 02:59 PM   #4
dfosh
Thanks for the info . We did the brakes on my sons 2000 Silverado four times.. Had to change rotors twice 160000 miles .Since the first time he has said the brakes were not as good as the factory. I didnt know if we messed up the abs system or not . We just pushed the pistons back to get the new pads in. We did clean all the parts while they were off . I didnt know if you had to do somthing to the abs system . My 99 has 51000 on it and will need brakes soon .
Old 11-08-2008, 06:51 PM   #5
truckdude239
truckdude239's Avatar
i just use a clamp never had no problems yet
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
