11-10-2008, 12:12 AM | #1 |
Frame Identification number
Hello everyone, can some one tell me where i can find some kind of identification number on my chevy trucks Frame? the thing is that i bought this 66 chevy truck c10 but i belive the frame is from a newer model truck and i need to know what year it was the only numbers i found on the frame were 467539 and 7 292s but i google'd it and did not come up with anything. if any one can give me a website or a different place to look i would really appreciate that. im thinking it might be around late 70's frame but need to be a hundred percent sure.
thank you all in advance. |
11-10-2008, 12:19 AM | #2 |
Re: Frame Identification number
the '60's frames have a VIN on the top of the driver's side, i believe slightly back from the steering gear. post some pics of your frame, especially where the steering gear is mounted
oh and
CHEVY ONLY |
11-10-2008, 12:25 AM | #3 |
Just saw vin numbers on a 76 frame, right side, top of frame behind cab, under bed.
Where were the numbers stamped on the frame in question? |
11-10-2008, 04:09 AM | #4 |
The vin on the 60's trucks is stamped on the drivers side top of the frame rail just forward of the motor mount. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 11-10-2008 at 04:18 AM. |
11-10-2008, 09:53 AM | #5 |
my '63's frame VIN is in front of the motor mount and behind the steering gear on top of the rail
CHEVY ONLY |
11-10-2008, 12:02 PM | #6 |
Ok these numbers i got were behind the drivers side under the Truck Bed on the side of the frame, i will see if i can find some more numbers maybe in the front by the motor mounts and maybe look in other places.
thanks all for the response. |
