11-15-2008, 01:40 AM | #1 |
Clutch Fork, Pivot Ball & Throw Out Bearing Question
It's been a long tiome since I messed with a manual trans....so forgive my ignorance!...LOL
Is the pivot ball retaining clip the only thing that holds the clutch fork in position on the throw out bearing ?? Is there no retainer on the clutch fork itself (around the throw-out bearing)... My clutch fork went on the pivot ball very easily and doesn't seem like thats enough to hold it in place....I did replace the retaining clip on the pivot ball....but I really thought there was another retainer on the fork itself at the throw-out bearing.. I'm getting ready to mate the Engine to the Trans and just wanted to verify that I have it right before doing so.... Thanks in advance! Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
11-15-2008, 04:19 AM | #2 |
Out of the carpool lane.
Re: Clutch Fork, Pivot Ball & Throw Out Bearing Question
For a Saginaw and Muncie I can say for certainty that there's no other retainer other than the pivot ball retaining clip. I'm 99.9% sure that the bigger transmissions are the same way.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-15-2008, 09:58 AM | #3 |
They call me the Breeze...
I just did a clutch recently and the clip was the only retainer for the fork.
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
11-17-2008, 08:57 AM | #4 |
The bell housing sort of holds the open end of the clutch fork on the throw-out bearing. The T.O. bearing is held on by the trans shaft. The clutch fork is held on by the pivot and the T.O bearing.
I have one 4x4 truck ['71 Jimmy] that has a threaded end on the rear of the lower clutch rod [not including the long threaded end that goes into linkage swivel]. This end goes thru the pushrod nut and thru the end of the clutch fork and secures the push rod to the clutch fork in extreme four wheeling mode. It may be a P.O.'s mod. My '68 C/10 has no back nut securing the lower pushrod to the clutch fork.
11-17-2008, 09:29 AM | #5 |
I miss this truck.
I'm in the middle of fighting this right now. Where did you find a new retaining clip?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
11-18-2008, 01:26 AM | #6 | |
Dan
11-18-2008, 01:28 AM | #7 | |
Dan
11-19-2008, 04:06 PM | #8 |
I miss this truck.
THANKS!!
I got lucky and found one local at the Volvo/GMC Heavy Truck dealer.
03-25-2015, 12:53 PM | #9 |
Guys, I'm new here and am struggling with this pivot ball and retaining clip. The engine/transmission supplier put together many parts for me to mate the engine/bell/tranny together. The part i'm having EXTREME difficulty with is the retaining clip. He supplied a regular round ball stud, and a tapered ball stud. The tapered one will install with the clip with great difficulty, but once I try to pivot the fork it springs out. Any suggestions out there?? I've been through two clips already trying to get this right. The regular round stud will not even come close to fitting properly.
03-25-2015, 01:07 PM | #10 |
Welcome Hump!!
Spring yet!! Always better to start your own thread than dig up a thread from the dead. More info needed. What tranny? What bellhousing? Stock fork? Pics would help a bunch! |
03-25-2015, 04:31 PM | #11 |
If you install a new pivot ball clip, make sure you have it in right. I got a new pivot ball from the transmission shop and once the fork was pushed on, there was a little bit of slop. In other words, it wasn't snug like my OEM pivot ball. I called my tranny shop and they said it was OK and that the newer pivot balls didn't fit as snug because the stem side of the ball was shaped different, but that it would be perfectly fine. I searched through my collection and found another OEM pivot ball that was in great shape and used it but could have used either one. FYI, NOS pivot balls are still available from some vendors. The 3rd pic shows the pivot ball that I DIDN'T use.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
08-30-2018, 12:07 PM | #12 |
Hey guys curious on how you put your clutch fork onto the pivot ball? I have been trying to put it on but it seems to not go on. Please help
Posted via Mobile Device |
08-30-2018, 12:33 PM | #13 |
What do you have and add pics so we can assist you if possible
08-30-2018, 12:45 PM | #14 | |
08-30-2018, 03:30 PM | #15 | |
Pay attention to Lugnutz post about clip orientation.
