Old 11-15-2008, 04:28 PM   #1
mjweimer
Looking to buy, what are common issues?
Group,
I am looking at a 2000 1500 4x4 with 85k miles auto and the 4.8. What are common issues I should know about when I go take a closer look and a test drive? I am most concerned with the function of the 4wd and anything related to the engine.
I am currently driving an '87 GMC 3/4 Ton 2wd so I am not too familiar with the newer trucks.
Matt
mjweimer is offline   Reply With Quote
Old 11-16-2008, 08:35 AM   #2
truckdude239
truckdude239's Avatar
Re: Looking to buy, what are common issues?
intake gasket leaks are the only thing i now to look for any kinda of leak that sort of thing
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-16-2008, 10:00 AM   #3
mjweimer
Thanks David. Interesting that the intake gasket leak is common, I looked at a truck last week that recently had these replaced but there were other issues I did not want to deal with...
Matt
Old 11-16-2008, 12:02 PM   #4
truckdude239
the problem is that gm installed the wrong kind of gasket on most of there motors and they aren't compatble with the dex cool antifreeze.
David fuller
2000 Tahoe 5.3l 378
Old 11-16-2008, 02:09 PM   #5
dailydragger03
dailydragger03's Avatar
Gen 3 chevrolet motors do not have coolant passages in the intake manifold. It is impossible for antifreeze to ruin the gaskets or the manifold because neither ever come in contact with coolant. This was a common issue on the 4.3 and 5.7 vortec motors in the late 90's. Dexcool is a horrible product and if your vehicle has it you should flush it out and use regular ethylene glycol antifreeze. Dexcool has been known to eat gaskets and pit metal. I had to replace water pump gaskets on my 5.3 T code at 40k miles. This is when I flushed out the dexcool and replaced it with regular antifreeze and a pint of rust inhibitor. The gen 3 motors are extremely solid I have heard of very little problems other than dexcool. Tune them up at about 100k miles and drive the wheels off of em.
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver)
1970 c10 short step just gettin started on it (project)
dailydragger03 is offline   Reply With Quote
Old 11-16-2008, 02:55 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I agree on the Dexcool, plus it will crystallize & can ruin your engine
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-16-2008, 11:11 PM   #7
truckdude239
i forgot all about the inakes dont see any coolant forgot all about it
David fuller
2000 Tahoe 5.3l 378
Old 11-17-2008, 01:11 PM   #8
bwood
bwood's Avatar
99-02 (maybe 03) 4.8, 5.3 & 6.0 had some issues with engine noise on cold start up. GM diagnosed it as piston slap and made adjustments to the warr on the engines. I may have the years wrong. I believe they fixed it with a revised piston on the newer models. Here is a link to a sticky on the Full Size Chevy Forum with more info (read through it as it also contains other recall info): http://www.fullsizechevy.com/forums/...nock-info.html
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
