Old 11-16-2008, 12:27 PM   #1
Conundrum
Conundrum's Avatar
Confused
I have an 03 silverado that is my wifes daily driver, the battery had went dead a couple of times in the last month and considering it was 5 years old I figured it was time to replace it. So I bought a new one and put it in, and we are still having a problem with the truck randomly dieing on us when driving it.
I had the alternator checked at the parts store and it checked out good.
Any ideas on what it could be?
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 11-16-2008, 02:20 PM   #2
463
463's Avatar
Re: Confused
clean the battery cables (make sure there tight) & check the ground wire to the frame/block/body. extra draw items such as comand/security sat radio will draw down a battery. a test to see if the alt is working is to pull off the + or hot cable off the battery when your running, if the engine stops the alt is not charging. the computer should have a code stored re: randomly dieing when driving it.
Trueman
463 is offline   Reply With Quote
Old 11-16-2008, 11:36 PM   #3
bwood
bwood's Avatar
Re: Confused
I know this works on older non computer controlled vehicles, but it has been my experince that the engine will die anyway and this could cause damage to the ECM.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 11-16-2008, 11:53 PM   #4
pilotj
Re: Confused
I had the same problem on my daughters 2004 Cavalier. Replaced the battery and it still would go dead at times. I was also having issues with interior lights and windows. It ended up being a bad body control module. I replaced it and had the vin flashed to it and havnt had a problem since.
1979 Chevy C20 350/TH400
1974 Chevy C30 350/4speed
pilotj is offline   Reply With Quote
Old 11-17-2008, 12:01 AM   #5
463
463's Avatar
Re: Confused
if it's got a chance of screwing the computer don't pull the + cable off when the engine is running.
Trueman
Old 11-17-2008, 08:13 AM   #6
truckdude239
truckdude239's Avatar
Re: Confused
never ever pull the battery cables off when running. it will cause a voltage spike that will fry the computer. i've had alts test good but be bad normally all mine seem the diodes go bad and pull back off the battery when the truck is off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-17-2008, 01:02 PM   #7
bwood
bwood's Avatar
Re: Confused
Pull the alt off and have it tested out of the vehicle. Testing it in the vehicle can make a bad one or one going bad still show good. Also who ever tests it (Oreilly and Autozone do it for free) have them do it a couple of times and maybe take it to a rebuilder and have them test it. Make sure the battery is clean also. Grease and buildup on the batt can simulate a small load if the buildup goes from terminal to terminal. I have also seen cases where the cable end looks good but if you strip the wire back the cable is full of corrosion. Something else to check would be to have the new battery tested. Take it out and put a good, slow charge on it and take it to have it tested. You could also charge it and let it sit on the bench for a few days and see if it drops drastically just sitting (you would need a voltmeter to check the voltage).
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 11-19-2008, 05:51 PM   #8
Conundrum
Conundrum's Avatar
Re: Confused
Thanks for all of your feedback, due to our work schedule and how early it gets dark and the lack of a garage I will have to try and get this fixed this weekend.
Old 11-24-2008, 01:13 PM   #9
Conundrum
Conundrum's Avatar
Re: Confused
I unfortunately did not get the chance to work on the truck this past weekend.
Although the truck hasn't died on either of us while driving it in the past week, we have noticed a high pitched whine coming from the engie compartment for a few seconds during acceleration.
I'm thinking it is the alternator..
Any other thoughts?
