11-30-2002, 09:51 PM | #1 |
Guage wiring--Again
I know this has been killed alot around here but I have a confusion question. Picked up a factory guage /bezel panel to use in my truck to replace the idiot lite one. Been reviewing what's needed.
1. need to rewire the connector for the changes 2. need a different temp sender Things I didn't find and are not sure of 1. is the oil pressure sensor the same for both idiot light & gauge or do I need to swap it out also. 2. My truck is a 70 and the guage panel came out of a 68. I noticed that if you went to buy a new dash harness they list the 67-68 as one item and the 69-72 as another item. What, if anything, is the difference and is this going to cause a problem. My engine is the 250 I6 if that makes any difference Thanks
11-30-2002, 11:15 PM | #2 |
Back in the sticks
The oil pressure goes to the oil guage thru a small diameter oil line. No sensor involved. You have to install a small fitting back by the distributor. I'm not sure on the differences between the years, but I swapped a buddies idiot light dash for a guage one, and all that I had to do was relocate the ground in the harness and one turn signal wire. Dark blue I think. Hope that helps, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
12-01-2002, 12:43 AM | #3 |
67-72 Addict!
Palf70step,
Go to GMCPauls site. He has a tech page and lists the procedure step by step with a schematic.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-01-2002, 01:19 AM | #4 |
its all about the +6 inches
red71cheyenne, you only had to move 2 wires!? When i slapped a guage panel into a light panel (not knowing the harnesses were differant) i had a whole bunch of lights not work properly, and my fuel guage fried after spinning around like on a cartoon or something. Did EVERYTHING work after just 2 wires being moved?
12-01-2002, 01:29 AM | #5 |
Back in the sticks
Those are the only two I remember. It might have been more, but those are the only two I remember. I just went off the schematic in my haynes manual. It didn't take very long, I remember that. Jeff.
12-04-2002, 12:03 AM | #6 |
Just wanted to try to speculate an answer of your question in reference to the differances in the older dash panel's. I believe the older ones had provisions for manual chokes and the 69 and newer had automatic chokes which counts for an additional hole in the panel. Is this correct??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-04-2002, 08:55 AM | #7 |
67-72 Addict!
69 and newer do NOT have the choke hole. You are correct!
12-04-2002, 06:42 PM | #8 |
I knew about the choke hole but I was wondering why the wiring harnesses were listed as different numbers. I was curious if there was something different in the actual wiring between a guage dasy for 67-68 and one for 69-72?
12-04-2002, 08:22 PM | #9 |
member #16
Is the wiper switch on the opposite side of the cluster?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
