Brake upgrade
Its been a while since I built an early chevy Ive got a 67 and want to upgrade to front disc but retain 6 lug and go to power brakes Which 73-87 should I look for, will the suburben or 3/4 ton fit or if I use half ton do they make a 6 lug rotor to fit?
![]() Join Date: Feb 2004
Re: Brake upgrade
From how I understand it, the 6 lug rotor is different. Your best bet is to upgrade to a 6 lug Suburban or 3/4 ton square body. It is the easiest and works out better for the power disc brake system, i.e booster, prop valve etc.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
![]() Join Date: May 2002
Re: Brake upgrade
GM never made a 6 lug 73-87 2wd. you would have to use the 5 lug stuff, and have the 5 lug stuff redrilled to a 6 lug.
i would just get a kit from one of the board vendors for the brake parts themselves. as for the booster, m/c, and proportioning valve, anything from a 71-87 should just bolt in. i'd look for something from a 3/4 ton for better stopping power.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 12-16-2008 at 10:37 AM. |
