Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-21-2008, 02:37 PM   #1
arkracing
Weekend Warrior
'84 K-20 Chassis (Parts or whole) & Aluminum Serp Setups
I have an '84 K20 Chassis with a 10b front end and a 14b semi-float rear end. I'm not sure what gears are in it though - I can check, but I think that the are pretty high for a 4x4 as the truck was originally a deisel and the PO converted it to gas. No motor/tranny, but I do have the NP208 that was in it. The chassis is in great shape - the only problem is that someone cut the back 12" or so of it, basically from the spring hanger back.
I'll part out the chassis if someone needs anything such as spring hangers or cab mounts, rear end, front end, springs, whatever.
$300 complete or will price parts if there is interest, or partial trade (I need a 3/4ton 10b Front End with 4.10 gears)
NP208 Transfercase with TH350/700R4 Adaptor and coupler $125
I also have a pair of the small fuel tanks that came out of a '81 SWB 4x4 truck. They are in super nice condition.
$50 for the pair with senders and brackets
I aslo have 2 serp setups - one is from a V8 and the other a V6. The both take the big A/C compressors. Great to convert your truck over to a Serp belt setup. Both units will include the powersteering pump and all the pulleys/tensior needed. I can also provide alts. for a few extra bucks. I only have pics of the one that came off the V8. They look the same and are both the aluminum ones (not the '88-'89) steel versions.
$75 each setup
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-30-2008, 09:05 PM   #2
mainermikeyd
mainermikeyd's Avatar
Re: '84 K-20 Chassis (Parts or whole) & Aluminum Serp Setups
I hate to even ask but I would be seriously interested in all the fuel lines front to back, an the hard part both cross member supports where the fuel tank lines run, an the one right behind mine are rotted beyond repair?? if not possible i understand, that suck bout the rear part of the frame, the rest is in fairly good shape!!!
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
