Old 12-03-2002, 04:58 PM   #1
smithjp1
smithjp1's Avatar
SWB vs. LWB
What is the length of the SWB vs. the LWB?
What is a c10 8' bed - is this a lwb or swb?
Thanks.
smithjp1 is offline   Reply With Quote
Old 12-03-2002, 05:19 PM   #2
Shane
Shane's Avatar
SWB & LWB refer to the wheel base.
115 inches = SWB = Short Wheel Base (OAL -bumper to bumper = 188 1/2")
127 inches = LWB = Long Wheel Base (OAL - bumper to bumper = 207 3/4")
(wheel base is measured from centerline of front wheel to centerline of rear wheel)
If you are reffering to the length of the BED
Shortbed Stepside = 78 1/4 inches long X 50 inches wide
Longbed Stepside = 98 inches long X 50 inches wide
Shortbed Fleetside = 78 1/4 inches long X 66 inches wide (width measured at inside of top lip)
Longbed Fleetside = 98 inches long X 66 inches wide (width measured at inside of top lip)
The 8 foot bed would be a longbed...
hope this helps...
Shane is offline   Reply With Quote
Old 12-04-2002, 04:59 PM   #3
Crank
Crank's Avatar
Also, you've got a *Longhorn* it is longer than a long bed, it has an additional 6" to the front of the bed and 6" added to the frame in that place. Which would make it a total of 133". Is that one right Longhornmail???
Brandon
Crank is offline   Reply With Quote
Old 12-04-2002, 05:07 PM   #4
crazy longhorn
Fabricate till you "puke"
That right on Brabra......the other longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-05-2002, 01:18 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yep...and of course there is the one ton step side...with a 9 foot bed.
