Old 12-28-2008, 12:48 AM   #1
ctouchet
ctouchet's Avatar
1978 2wd Frame -1985 4wd Frame
Will a 1985 Chevy Blazer Body fit on a 1978 Frame?
2012 F150 SuperCrew
2011 GMC 1500 (COMPANY TRUCK)
1982 Chevy Blazer 2WD (Work in Progress)
ctouchet is offline   Reply With Quote
Old 12-28-2008, 01:15 AM   #2
vern350
like a rock
vern350's Avatar
Re: 1978 2wd Frame -1985 4wd Frame
They should. Only think different, may be the transmission humps being different heights. The front frame rails between the two are different, but the 78 front frame can be easily modified to accept a 85 style bumper.
vern350 is offline   Reply With Quote
Old 12-28-2008, 03:12 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-28-2008, 01:20 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
You'll have a problem with the body mount behind the doors. 73-80 they bolt to the crossmember, 81-91 they bolt outside the frame...
chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-29-2008, 11:03 AM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Yes the from is not the same after the doors. Sorry man...
tvblazer78 is offline   Reply With Quote
