Old 12-04-2002, 10:18 PM   #1
Bowed
This is getting old fast !!!
For the second time I took out the 3 speed standard transmission in the 75 C10 that I got recently , trying to find that mysterious knocking noise that comes from the bell housing area ( It had the noise when I bought the truck ) and while looking thru the repair manuals I noticed the bolt pattern did not match any thing in the manuals . It has a 5 bolt pattern and all the transmissions in my manuals are 4 bolt pattern so now I wonder if my problem is that some body put a mis fit in there . The trans is a GM21 ( 352259 ) ( H30 -4 ) can any body tell me if this is for 75 chevy ?
Bowed is offline   Reply With Quote
Old 12-04-2002, 10:27 PM   #2
Stano
Stano's Avatar
I have had both kinds of trannys in my 67 before. 4 bolt pattern and 5. They are out of the mid 70's and up I believe. As far as the noise you mentioned it might be your throw out bearing. I have had them make tapping noises and such even new ones.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 12-04-2002, 10:31 PM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Are you sure the noise is coming from the bellhousing area and not the rear end, sound will often travel thru a driveshaft?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-04-2002, 10:44 PM   #4
Bowed
Running with the drive shaft off still makes noise , running with the trans out there is "NO" noise so the clutch and plate must be OK and not hitting any where . The clutch fork and throw out bearing are brand new from when I took it out a couple of weeks ago . There was some mickey mouse work done on the linkage so Im thinking may be some mix and match done on it to cause a problem .
Old 12-04-2002, 11:32 PM   #5
fast_dev
fast_dev's Avatar
i have seen a bad pilot bushing make a knocking noise, sounded bad. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
