Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 12-06-2002, 01:38 PM   #1
COBALT
COBALT's Avatar
Fel-Pro 1-piece oil pan gasket ('75-'85)
FEL-OS34510T. You can get it at Summit Racing for $32.39.
It Rocks. The only sticky part is using the plastic snap studs that screw into the corner holes to align the gasket and oil pan. You have to be careful not to snug down the smaller bolts until you get those studs out. They can be stubborn, and if you twist them too much trying to get them out they'll break. Also make sure your oil pan holes line up perfectly, so the studs come out easily.
Also, the pan bolts have to be extra long so they go through the gasket. You can use stock bolts, but you may not get enough bolt into the lower deck of the engine block, and you'll have to use a floor jack to push the pan against the block to get it close enough...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 12-06-2002, 11:39 PM   #2
racedvl
racedvl's Avatar
I use nothing but that! Both my trucks have it, and I would not have it any other way!!
racedvl is offline   Reply With Quote
Old 12-17-2002, 07:53 PM   #3
CustomChevy
studs
it's much easier with studs all around. moroso has a kit, summit sells it. worth it!
CustomChevy is offline   Reply With Quote
Old 12-19-2002, 12:18 PM   #4
MikeB
MikeB's Avatar
I've had mine in and out several times and it still looks like new. When I sell my current motor, I may keep the pan gasket! I have 3 or 4 of the old style pan gaskets sitting un-loved on the shelf.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-22-2002, 09:26 PM   #5
72 Super
72 Super's Avatar
I,ve been thinking about using one on my truck.It wwould worth the price not having any more leaks.I,ve heard you dont have use any type of sealant is that correct???:
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 12-22-2002, 11:48 PM   #6
racedvl
racedvl's Avatar
Install dry.
Old 12-31-2002, 04:45 PM   #7
Truckstr
Truckstr's Avatar
I'm thinking seriously of getting one of these, but I have a question.
The Summit website has the following 'blurb' listed in the 'overview' of the part:
"Chevrolet: 1975-85 262-400, oil pan gasket
This Fel-Pro OEM oil pan gasket set is ideal for stock replacement use. This gasket is not intended for race applications."
My question is, why would it say "...not intended for race applications"?
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 01-16-2003, 12:52 PM   #8
Truckstr
Truckstr's Avatar
Originally posted by racedvl
Install dry.
I installed one recently and the instructions call for a small amout of silicone based RTV at the junction of the timing chain cover/oil pan/block in the front and at either side of the rear main cap at the block.
I did that and - so far - no leaks. I'm very happy.
See ya,
Jeff
Jeff
Old 01-16-2003, 02:21 PM   #9
COBALT
COBALT's Avatar
I think they call for RTV if you don't (or can't) use the guide studs if I remember right, because the primary reason for the RTV is to keep the gasket in place.
Another critical thing I forgot to mention with this post is the old rubber sealant on the front and back flanges (where the cheezy rubber things go) has to be cleaned off before this thing goes in. If there's residual rubber sealant still hanging around then it will distort this gasket, and it won't fit right at the corners.
Seattle, WA.
Old 01-27-2003, 02:29 AM   #10
crazy4chevs
crazy4chevs's Avatar
I havent ever heard of them before. I will have to check them out.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 01-28-2003, 02:47 PM   #11
81lwb350
big block lover
did the longer pan bolts come with it?
im changing my pan gasket soon...leaking like most...
and this is the gasket i wanna get...
i have a 69-327
thanks
anthony
81lwb350 is offline   Reply With Quote
Old 01-28-2003, 03:21 PM   #12
COBALT
COBALT's Avatar
HA! I'm glad you asked that. Yes, it comes with longer pan bolts (see pic above - It's from Summit Racing).
I actually made the mistake of buying stainless bolts to put in, and then realized later I had to use the longer ones...I didn't bother to go back to the store to get longer stainless. I was a bit tired by then, and wanted to get the DAMN thing done.
Seattle, WA.
Old 02-19-2003, 04:12 PM   #13
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I have that one also...got mine from O'reilly's. I am pleased with it also.
Suicide-D is offline   Reply With Quote
Old 03-08-2003, 09:51 AM   #14
68 Suburban
68 Suburban's Avatar
Loepers in Phoenix has them for $24.
68 Suburban is offline   Reply With Quote
Old 03-21-2003, 10:40 PM   #15
trailwart
trailwart's Avatar
this gasket is sweet. got em on my trucks and no leaks. they sell em at autozone.
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
