Brake Question
I have a 1972 GMC Super Custom 1500 and was wondering how the brakes rated. My truck stops fairly well, but if I needed to to make a quick stop in this L.A. traffic gridlock, I might be in trouble. I know it'a a truck and all, but I know they can be better. My brake system seems to be in good shape. I just put new pads on it and a new master cylinder. I want more response out of my brakes. How were the brakes on these trucks when they rolled off the lot? Any suggestions would be appreciated.
Aaron Ventura, Ca. 1972 GMC Super Custom SB350/TH400 |
brakes
Are they power brakes? Does it take much pedal pressure to stop.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
14.1 @ 96MPH
I can't comment on out-of-the-factory since my front discs are a conversion (using a lot of factory parts, though; I used the Early Classic 6-lug kit, the only custom parts in the kit were the spindles and the 6-lug rotors) and while it won't really put you through the windshield like my brother's '94 Z28 or my dad's '97 E320 will (both have four-wheel discs with Kumho tires and ABS), it does get a 4000lb truck stopped pretty damn well. IMO, newer truck brakes aren't a whole lot better.
Just make sure everything is working well...and if you want some simple upgrades, try Praise Dyno pads/shoes...I don't know their address...but some of the guys here with four-wheel drums still installed their shoes all the way around and say it made a world of difference, so I can only imagine what it'd be like with them on a disc/drum truck...they're kevlar pads, by the way.
Project1970 - LS1 Swap Complete! ![]() |
Yes, they're power brakes and it does seem like it takes a little much to stop.
What if?
well i had to convert mine back to manual brakes,my booster went out and due to xmas no funds.
all i can say try stopping on manual drum brakes ![]() |
brake booster
Here is a way to check to see if your booster is working:
with engine off pump brake pedal 4 or 5 times--hold pressure on pedal and start engine--if pedal moves down booster should be ok--if it does not move booster is bad. I have a 71 Cheyenne with power brakes that takes very light pressure to stop. Hope this helps.
Grubbin'
I'd suggest trying to stop on manual drum brakes on a whindy road next to a cliff going about 50 or so. That's how I found out about bad braking when I test drove my 69 for the first time. Oh, don't forget to bring an extra pair of undies!
project rust attack 1969 Chevrolet LWB w/ 307. I got power steering now woohooooo!!!!!!! |
