Old 12-08-2002, 01:17 PM   #1
72K10
Question Electric choke wiring question?
Where is the electric choke wired to on an Edelbrock 1406? Is it to a fuse that's on only when the key is on, such as the radio? Thanks,
Chris
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 12-08-2002, 01:20 PM   #2
racedvl
racedvl's Avatar
Yes. Key on only.
racedvl is offline   Reply With Quote
Old 12-08-2002, 01:35 PM   #3
72K10
Just read that the 1406 choke needs a full 12 volts; if you don't give it the full 12, it will run rich (sounds like what mine's been doing). Do all the fuse slots provide a full 12 volts? Thanks!
RLTW
70C10
72K10
72K10 Cheyenne
Old 12-08-2002, 02:20 PM   #4
jhow66
jhow66's Avatar
choke
Yes all slots will be 12 volts. To make your choke work better purchase a oil pressue sending unit with 2 prongs on it and install it with a T fitting where your original one is(keep original also). Hook wire from fuse panel to one side--the other side to choke. This way choke does not start heating until engine starts and has oil pressure.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-08-2002, 03:37 PM   #5
72K10
Very slick idea!! Thanks much.
RLTW
70C10
72K10
72K10 Cheyenne
