Bed side help
Well I am working on the bed of my 55 and the sides are shot imo. They have had patches welded in where the wood meets the sides. That looks ok but my main prob is that they are really wavy from being hit for all the years. Can anyone give me some advise on how to get these straight without using a gallon of plastic. I am still learning how to work the metal so please forgive me. I would just buy new sides but we really dont have the cash for new sides. Thanks for any help or advise.
72 Shortbed, fleetside, 4x4, 307,4spd. 55 second, 350, 4spd, almost done 77 K-20, 454, 4spd, plow truck 96 K-1500, 6 inch lift, 178k still going strong |
Re: Bed side help
Check with Mar-K and see if they have new ones for your truck, you will be very happy with there product.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Re: Bed side help
They have new ones but I dont have 1100 for new sides. I wish I did but I think I need to save these unless I can get a smoking deal
Hollister Road Co.
Re: Bed side help
They are a real PIA to get straight. You need to stretch and shrink the areas that are wavy. Its more an art form and would need an experinced body man. Best thought would be find some good used or possibly if your up to a project just buy the flat sheet metal and replace the entire lenght.
Its to cold up there for that kind of work anyway. I remmeber driving down Shelter Rock one winter night in the snow or I'll say bouncing off curbs all the way down. Almost landed on the roof of the Helicoil plant. Last edited by dwcsr; 01-21-2009 at 11:46 PM. |
Re: Bed side help
http://67-72chevytrucks.com/vboard/s...d.php?t=324188 Check out my build I made mine out of 2x4 steel tubing and flat steel. I had the tubing cut on 45's and a 1/2" lip bent around the flat steel to plug weld them to the tubing. Steel and labor was like 300 bucks, and I like them better than stock. JMO. I looked for a good set for years and couldn't find them, until I had this bed ready to paint. Then low and behold we found a good set less than 10 miles from home for 60 bucks, needless to say we have an extra set for the next project.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 01-22-2009 at 09:41 PM. |
Hollister Road Co.
Re: Bed side help
Thats kind of what I was talking about. If you didn't want the square tube you could use the old top rails and stake pockets from the old bed.
Re: Bed side help
I think I am going to just get some flat 16ga and make my own and use the old top rail, just put a flange on it and weld it solid. I have a 12ft sheer and a 10ft brake so it shouldnt be that bad.
dwcsr, my family owned a farm on shelter rock were I grew up, the hill is alot of fun in the snow on both sides.
Re: Bed side help
If you don't have a lot of cash, go down to your local wrecking yard a find a set of used bed sides. The bed sides are the same from 1955 to 1987 on the step side beds so there shouild be plenty of them out there. If you get a newer year you will have to re-drill some hole for the fenders but the rest will bolt right together.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#9 | |
Re: Bed side help
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
#10 | |
Re: Bed side help
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Hollister Road Co.
Re: Bed side help
I know the area he's in and its rustville USA. Your lucky to find a truck in any shape that old let alone good bedside.
