Old 01-22-2009, 09:22 PM   #1
youngrodder
youngrodder's Avatar
Grill dimensions
I am in need of a dimension from a 47-53 Chevy truck grill. I need to know the width of the grill from side to side. I am trying to mock up the front sheet metal and I need to know the proper distance between the front fenders.
Thank you
Marc
youngrodder is offline   Reply With Quote
Old 01-22-2009, 11:42 PM   #2
solidaxel
solidaxel's Avatar
Re: Grill dimensions
Are you at a point that you can put the hood on and make the fenders fit to the hood?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-23-2009, 09:27 AM   #3
youngrodder
Yes, but without a grill in place the fender tend to fall a little which causes a bigger fender to hood gap. I was going to make a steel pipe the same width as the grill so that the spread of the fenders are correct.
Marc
Old 01-23-2009, 01:30 PM   #4
mylow53
mylow53's Avatar
ill try to measure mine for you tonight.
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 01-23-2009, 02:43 PM   #5
youngrodder
GT
Thanks Greg. I had a mock up grill but I must have taken it to the scrap yard. I am still scratching my head over where it might be.
Thank you in advance.
Marc
Old 01-25-2009, 11:08 AM   #6
youngrodder
Marc
bump
Old 01-27-2009, 09:27 AM   #7
youngrodder
Anybody..........
Old 01-27-2009, 10:34 AM   #8
cajundragger
it has a taper to it so your going to need two pieces of pipe, but I can measure my grill this weekend if nobody else helps by then.
cajundragger is offline   Reply With Quote
Old 01-27-2009, 11:32 AM   #9
mylow53
mylow53's Avatar
sorry marc here are the measurements
top left to right 46" exactly
bottom left to right 48 1/2
this is not the original but a reman.
hight is roughly 16"
Greg
Old 01-27-2009, 12:23 PM   #10
youngrodder
Thanks Greg..
I will make up some bars tonight to simulate the grill.
I will be going with a reman as well.
Marc
Old 01-27-2009, 12:25 PM   #11
youngrodder
Good point cajun
I forgot about the taper. I am still pissed that I threw out my mock up grill. I must have got too excited when I took a bunch of scrap metal to the yard $$$$.
Marc
Old 01-27-2009, 02:47 PM   #12
mylow53
mylow53's Avatar
i still have my old original it's dinged up but if your painting it and have some patience it would work..
GT
Greg
Old 01-27-2009, 03:00 PM   #13
youngrodder
GT
I appreciate the offer. At this point I think that I am going with a chrome reman as well.
Marc
Old 01-27-2009, 05:30 PM   #14
cajundragger
on the remans....make positive you start from BARE metal and build them there. I got one that was painted in some kind of enamal I guess, but the metal was completely rusted beneath the paint.
the grill was brand new FYI.
Old 01-27-2009, 10:14 PM   #15
youngrodder
Your grill was chrome, so you mean the painted part of the grill was screwed up underneath. Where did you buy it from?
I am sure they all come from the same place, I was just curious.
Marc
