Old 01-23-2009, 06:48 PM   #1
IvanfromtheCrackie
IvanfromtheCrackie's Avatar
Smile Who is Cutting Where???
Been lurking for years.
Cal58 and mylow53 motivated me to do a truck build so I picked up a swb 54 with a 235 and three on the tree. Down to the frame, planning on 4 linking the rear with a 70 Camaro rear end I had laying around and I also am in the middle starting a Camaro Clip swap. Actually its probably a Malibu or Nova front end since it seems to measure closer to that than an actual Camaro front end.
Anyhow...
Ive read several threads on clip swap and seen a few pictures even but it seems like there is really no "exactly right here" place to cut.
I'd just like to know where most of you who have done the swap are cutting your frames?? I have welding experience and have built a few Hot Rods so it's not like I'm afraid to do what needs to be done.
Just want some opinions and pics of what you guys have had success with since I know how easy it is to really screw something like this up.
Thanks all and I appreciate the Forum,
Ivan
IvanfromtheCrackie is offline   Reply With Quote
Old 01-23-2009, 07:02 PM   #2
mylow53
mylow53's Avatar
Re: Who is Cutting Where???
to be lumped in to cal's class is a mistake he has a work of art!!! as you know we need pictures!!! the more the better. no progress is to small to take a picture of. lastly when your wife complains about how much time and money you put in to this don't bring up my name.
Greg
ps mustang 2 front will maintain your investment dollars more then a frame graft. i prefer as much stock as i can. provided it still goes fast and is safe.
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 01-23-2009, 07:36 PM   #3
blackdiesel
blackdiesel's Avatar
Dads truck has the dodge dakota front end from Industrial chassis inc. it works (rides) very nice and is heavier duty than the mustang. IMO
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-23-2009, 11:06 PM   #4
solidaxel
solidaxel's Avatar
Welcome from So Aridzona!
I like the idea of the Mll, and my new build has a Dakota from Industrial Chassis.
These folks have done a lot for the hobby, so think about it before you chop your chassis, and you have RACk & PINION steering. jm.02
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-24-2009, 12:36 AM   #5
IvanfromtheCrackie
Greg
In my opinion, you belong in that class brother. You've made some nice moves on that rig.
I already have the front end and would rather spend the cash on a good nice set of wheels than to put a (what I feel is a under-engineered) car front end on a full size truck/frame.
Again, my opinion and it's only that-an opinion. I'm def not going to be in your class at all. I'd be surprised if I put what you have in your frame in my total project.
You and Cal motivated me by seeing your work and letting me know what a basic and ugly looking truck can look like with a little "love."
So.....getting the thread back on track.
Anyone with cutting ideas and/or "general vasectomy" areas???
Just wanna see where you guys end up cutting and making the point of attachment.
Thanks again fellas,
Ivan
Old 01-24-2009, 09:19 AM   #6
solidaxel
solidaxel's Avatar
Take a look (measure) the dia. of the camaro spindle and comare it to the Mll spindle.
You will be surprised at how much larger the Mll is.
"Them Ford folks build a good tractor"
LS 3 4L70E
Old 01-24-2009, 11:33 AM   #7
IvanfromtheCrackie
I'm sure that the MII isn't a bad idea and Id consider going down that road of I were starting from scratch. I like the Camaro clip and yeah its not as easy either but I just don't see what's wrong with going with the Cam Clip if I've already got a good one and I'd rather spend the money elsewhere.
A decent (even used) MII front end is gonna cost me at a minimum $800 and can go to "oh my gosh" really fast if you like tubular and chrome and big brakes.
Aside from Cal58's truck being a well, 58 that's exactll how I'd like my rig to lay out.
Just my way of thinkin, sorry. I like the MII and if I were building a turnkey or showstopper then yeah, it's the clip.
Thanks for the input guys,
Ivan
Old 01-24-2009, 03:49 PM   #8
blackdiesel
Ok, I will take a poke at this one. I didn't sub mine or dads truck, but I did sub my 38 coupe. We started in a good level spot in the shop, put it up on stands, using a plumb bob marked out the hub centers frame horns and any other reference points that you feel are necessary. Then look the two frames over good and measuring several times, and when you fill you have all the mesurments where you want them, break out the torch. Look at all the build threads on here you can get some real good ideas from them. There are several ways to sub, some are better than others, so do some research and go for it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-24-2009, 08:41 PM   #9
entourageguy
Yellow truck club
entourageguy's Avatar
Here is some good reading from the HAMB on doing a front clip....
http://www.jalopyjournal.com/forum/s...ght=front+clip
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-24-2009, 10:09 PM   #10
IvanfromtheCrackie
Now this is what I was asking for....thanks guys.
I'll let you know how it goes,
Ivan
