12-08-2002, 11:52 PM | #1 |
silly question, will high hump cab work with my th350?
sorry i dont know much bout these trucks and i want to make sure before i drop the money on this new cab im going to buy.
im about to buy a 71 cab with the high hump. right now my 72 has the low hump and th350. i just want to make sure a high hump will work ok with my current th350 and the 700r4 i plan on swapping to in the future. i have a column shift now and intend on keeping it that way. |
12-08-2002, 11:58 PM | #2 |
Fabricate till you "puke"
It will work, you will just have a little extra clearance tween the floor & the trans.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
