Are the brake boosters the same between C 10 and C 20 ?
Just wondering . I have a booster from a 71 C 20 and I need one for my 72 C10 will if fit and are they the same design I dont want somthing that does not look correct because I am not building a farm truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
"Ochre Ogre"
Technically they are not the same. The C10 will be a single diaphram and about 3" thick while the C20 will be a double diaphram and about 5" thick. I have never tried it, but people have said you can use a dual in place of a single.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
GYRO GEARLOOSE
I use one out of an 85 Citation, smaller, seems the same 'boost' to me.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
Ain't we cute?
I use a C20 unit in my C10. They say it has more stopping power and I think I believe it. Even with a leaky MC and line, this truck stops like a sports car (at least empty and in a straight line).
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 ![]() |
cool does it look similar to a c 10 stlye ? or really out of place if it makes more stopping power which it should because you need more brake power to stop a 3/4 ton load i may consider using it.
I'm using a 3/4 ton booster as well. Works good.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
Almost Satisfied
![]() Join Date: Mar 2002
I believe they are bigger than the C10's. I had a C20 on my truck years ago and it was visibly larger. I didn't like the look of it. In your truck I would say you would want a smaller booster for looks.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
cool thats what I was thinking I will see if I can trade this for a C10 one . What are you gonig to run on your truck ?
Ain't we cute?
From what I understand, there are several styles/sizes, even on C10s, due to different motors, clearances, etc.
Mine looks similar but not exactly the same as the big block units, thicker front to back. You shouldn't have a problem with clearance unless you have a big block, and probably not then either. You MIGHT if you were to adapt one from a later model truck as they had a pretty big diameter.
Almost Satisfied
72Mario, I think I will fork over the extra cash for one of the reproduction units from somewhere like Classic Performance since they are smaller in diameter. I may just order a new C10 reproduction unit though since I am going back to a stock looking engine compartment (very dressed up, but no shaving)
I believe your truck is shaved on the firewall, right? If I would have done that I think I would have gone for the frame mounted booster. It always seemed a little pointless to shave your heater box and then have all this brake stuff sticking out on the other side...that is why I choose to leave mine stock. Your truck is looking sweet. Let me know what you choose to do. I would like to see how it turns out.
imo brake parts are nothing u wanna screw around with. i would get a new booster if i were u. i replaced everything with new or rebuilt parts b/c the truck sat for three years plus u gotta remember these parts are 30yrs old. a new booster isnt all that expensive to risk it
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
My other Love
If you want a small booster, order one that is made for clearance of tall valve covers. I think they were optional in 1st gen camaros
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
