CoonHunter
Electrical Question
I've been having a problem with my heater blowing faster and my headlights getting brighter then flickering back and forth. What could be the problem? A ground, a alternator? Any help would be appreiciated. Thanks...
72 Chevy 1/2 ton 4x4 4" inch lift. 2000 Chevy Malibu |
Resident Young Old Dude !
Travis,
Do you still have the "stock"Voltage regulator?? That sounds as if that is the problem. You may want to check the grounds just the same. And does it happen at a continous RPM, or at varying rpm's? Just the same though, It still sounds like the Voltage regulator is getting ready to take a dump. Even the newer 1 wire alternators have an internal regulator. RON |
My other Love
It's easy to convert to internal regulated altnernators. I got sick and tired of fiddling around with my regulator so I put in a alternator out of a 77 chevy. I will do the same thing in my Monte when I put it back together. Its just a lot more reliable
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
