OT Help me with suburban
sorry to be off topic .. but i have to get a fix quick. On my 99 suburban, the ac controls won't change air flow from the defrost, no matter what I do. It is stuck blowing through the defrost vents, what gives? Is this a common problem with that year suburban? Any help is appreciated! thanks in advance
Is it auto climate control?
I would check all the fuses first. If all the fuses are ok then I would make sure the bleand motors were getting power. You will need the service manual to diag. this problem, if a fuse doesn't fix it. ![]() |
Sounds like a vacumn problem--check main vacumn feed to heater controls.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
