Old 12-10-2002, 01:01 AM   #1
wxman1
Instrument Cluster Replacement
I've decided to replace my instrument cluster with
a custom setup. The tach,oil,temp and ammeter guages
are available at a number of parts houses. I'm fabricating
my own instrument panel.
My problem is the speedo and the fuel guage. I'm told
that Autometer makes a speedo but I've never seen it
in any of the local parts houses. I also don't know if its
electrical or mechanical. I'd like to stick with a mechanical
speedo since the cable is already there. I'm stumped on the
fuel guage. Is that impossible to do...or is there an aftermarket
fuel guage available? And would that require changing the
fuel sending unit?
Anybody with any experience doing this?
Jim M.
Mt Juliet, TN
wxman1 is offline   Reply With Quote
Old 12-10-2002, 01:15 AM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
goto Jeg's website
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 12-10-2002, 01:19 AM   #3
cableguy0
autometer does make speedos in either electric or mechanical. summit and jegs both have quite a few in their catalogs. as for the fuel guage autometer has quite a few choices and im pretty sure most aftermarket guages are setup to work with the chevy style sending unit but im not totally positive on that. also a few people on here have done what u are doing maybe on of them will respond and be able to help you out a little better.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-10-2002, 10:49 AM   #4
fatfords
fatfords's Avatar
I used the Autometer #2514, 2 1/16" diameter, electrical fuel gauge, 0 ohm empty, 90 ohms full. It works with the original GM sending unit.
They have several styles to choose from, all of which have a part number to work with a GM sender. Take a look at www.autometer.com.
Good Luck,
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
