Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-03-2009, 01:51 AM   #1
Super73
Super73's Avatar
Suspension 101
Wow, what an overwhelming topic.. I am no expert and there is always room to learn new things, but I am going to try and delve in to the basics of suspension and give some recommendations as far as reading material. I want to use this thread as a general overview that can lead to more specific questions and in-depth answers.
Chapter 1 - Front Suspension:
Now, the trick to getting your truck to hook is putting the weight on the rear tires. The way to do this is to store as much energy as possible in the front end. To do this, you want to use the longest/lightest spring possible. This makes the front end very easy to lift when you need to transfer the weight off the line.
Most of our trucks are independent fronts based on 1960’s technology. From what I understand 1960-1983 front cross members for the most part are interchangeable. So this is going to cover them.
When figuring out the right spring rate and length you must know axle weights, unsprung weight and leverage ratio.
Unsprung weight is the weight of the:
Rotor
Caliper
Spindle
Rim/tire
½ of the shock
½ the spring
½ of the upper and lower control arms.
Here are some weights I have figured out:
Rotor: 26lbs
Caliper: 9lbs
Spindle: 27lbs
Lower control arm: 22lbs
Upper control arm: 10lbs
Shock 10lbs
Spring 15lbs
Rim/tire 30lbs (This is a guess)
So based on this, unsprung weight would be 121.5lbs * 2 = 243lbs. So if your front axle weight is (2260lbs), you will need to figure out springs on 2,260lbs – 243lbs = 2,017lbs and leverage ratio.
I have also figured out leverage ratio on our trucks to be 1.91-1. This is the leverage put to the spring due to control arm length. If the center of the spring was at the ball joint, the ratio would be 1-1 since the spring would compress 1” if the ball joint moved 1”. Leverage ratio 2-1 would mean the ball joint would move 2” for every 1” of spring. With a leverage ratio of 2-1, the spring is caring 2 times the sprung weight it would if the LR was 1-1. Our LCA is 17.25” from the shaft to the ball joint and our spring center is at 9” (9 / 17.25 = 1.91xx)..
So 2,017lbs of sprung weight with a leverage ratio of 1.91 would be equal to 3,866lbs on the springs. This number needs to be divided by 2 since there are 2 springs that support the front ends weight. Your front spring needs to be able to support 1,933lbs each at you desired ride height. If your truck sits where you want, take a tape measure and climb underneath the front. You should be able to slide the tape up the hole in the lower control arm where the spring sits. Put the tape up as far as it will go and write down the measurement to the LCA where the spring is. I like where my truck sits height wise and mine measures 9”. This measurement I am going to refer to as compressed ride height. If you desire a 9” compressed ride height, you need a spring that supports 1,933lbs each side at 9” compressed height.
Our front ends use a 5” spring. Below are some Moroso springs and the details for them:
Spring - Length - Rate - Coil bind (compressed)
47180 -- 19.500 -- 212 -- 7"
47140 -- 17.375 -- 240 -- 7"
47195 -- 18.000 -- 250 -- 6.875"
47170 -- 18.625 -- 270 -- 7.25"
Spring rate is how much weight it takes to compress a spring 1”. With that being said spring 47140 with 1,933lbs on it would compress 8.05” making the compressed ride height 9.32” (17.375” – 8.05” = 9.32”). That’s .32” more than your desired compressed ride height and with a leverage ratio of 1.91-1 it equates to .62” higher than what you were looking for. Keep in mind though, springs will settle some and eventually lower the stance a bit on their own.
Here is a link to an excel spreadsheet I put together as a tool for myself. It will do all auto calculating, so only enter info in the colored boxes.
Yellow boxes are for you to change.
Red boxes should remain unchanged unless your suspension is different or you have weighed your own parts and they are different than what I have in there.
Green boxes will reflect the data you need based on the info you put in to the yellow boxes.
http://73-ls1.com/67trucksetlist/Dat...g_sheet_v2.xls
Chapter 2 – Rear Suspension
Focused on the 60-72 rear suspensions but theory’s should apply to all ladder bars in general.
Squat/Anti Squat
Springs for the rear
Antiroll bar
Pinion angle, what happens under squat and antisquat
How fast can I go on the stock rear suspension?
I have a 60-72 Chevy pickup and I want it to hook. Should take the trailing arms out and run a ladder bar?
These seem to be common questions around here. What does our truck have from the factory? To tell you the truth, we have a great rear suspension platform to build from. Our trucks are blessed essentially a very long ladder bar. 52” to be exact. We are going to go over what or how we can make this set up work for drag racing.
What causes squat and antisquat? How does it help/hurt in situations?
Simply put squat is when the rear axle goes up in to the body of the vehicle causing the rear to “lower” under acceleration. Antisquat is just the opposite. The rear axle actually is forced in to the ground as the chassis separates from the rear axle. Squatting the rear suspension allows energy to be absorbed in to the chassis, sometimes a good thing. Antisquat puts that energy in to the tires forcing them in to the ground and sometimes adding traction.
How to figure antisquat out.
You can figure out antisquat fairly easily. It just takes a little leg work. You need to know where you center of gravity is both front to back and height and where your instant center of gravity is. To determine center of gravity front to back you need to get axle weights. If you have 60% in the front and 40% in the back, then take your wheel base and divide it by that amount. 100” wheel base would put you at 40” from the front axle. The height is a little more difficult.
For height you still need to put your vehicle on scales. You will end up putting your front axle on the scales. You must fix your front suspension from moving as we are going to jack up the rear axle at least 10 inches. If the front isn’t fixed, it is going to compress the front suspension and you won’t get a true reading. You will notice that your front axle weight will go up as you raise the back. Make sure to write down how many inches you raised the vehicle and what the front weight went up to. To make it even more accurate, take 3 readings (10” 12” and 14”)
Here is a link that you can put your data in to to give you the info you need: http://www.longacreracing.com/articles/art.asp?ARTID=22
Now, to know where your instant center or gravity is. From a side view, you would theoretically draw a line from your rear tire contact patch through the mounting hole for your truck arm. If your instant center line goes straight through your center of gravity, you will have 100% antisquat. Don’t let the percentage fool you. 100% antisquat means you will not squat the rear nor have any antisquat. But anything below 100% will squat and anything above 100% will induce antisquat.
Hopefully this crude drawing helps you understand what I am talking about.
Springs for the rear are very similar for springs for the front. Again, a light spring rate and long spring will give you more flexibility. The leverage ratio works the same here. You can use the previous spreadsheet for the rear too. If you moved your rear spring, you will have to adjust for that, also unsprung weight most likely will be different.
One thing that needs to be considered in the rear is shock location. Is your shock better off in front or behind the axle? What’s the difference? Well, if the shock is right at the axle, there is no leverage ratio applied. For every 1” of travel, the shock will move 1”. If the shock is behind the axle, for every 1” the axle moves, the rear shock will extend more than that. If it’s in front of the axle it will move less than that 1”. With a 52” bar, if your shock is at 26” (26/52=.5) your shock will move .5” for every 1” your rear moves. If it’s at 65” then (65/52=1.25) so your shock would extend/compress 1.25” for every 1” of axle movement. You will ultimately have more control if the shock is behind the axle. With an adjustable shock, every change to the valving will make a bigger impact due to the stroke of the shock being more. For an overly stiff and short shock, in front of the axle might be the way to go.
Antiroll bars in the rear help axle rotation and aid in keeping your vehicle level during launch. Your rear axle wants to rotate the same direction as your drive shaft under acceleration (Passenger side wants to go up in to the body while the driver wants to go down in to the ground). When this happens, the rear axle is physically rotating under you vehicle making your vehicle “twist”. An Anti roll bar will help fix that. When the axle rotates, it is also causing your lower control arm lengths to change. When this happens, your axle is no longer straight. It will cause the driver side wheel base to differ from the passenger side slightly causing the axle to no longer be aligned straight and the result is you go sideways.
Black voodoo, “Pinion Angle”. Let me start by providing a link to CarCrafts site that I feel does a pretty good job explaining setting pinion angle: http://www.carcraft.com/howto/91758/index.html
Now, with our trucks, I have figured for every 1” of axle change (up or down) the pinion angle will change aprox 1*. With our set up, you won’t see much pinion wrap due to it being a ladder bar by design. There might be a little do to the material used in the front mounting holes in the lower control arm, but the rear is fixed to these arms. The arms would have to bend which I guess is possible if you are making a ton of power, but at that point, I think you have other issues.
When the rear squats, the pinion will want to point down. When the rear has antisquat, the pinion will start to point up. This is something to consider when setting up your rears pinion angle. To get best results, I feel under load you should have 0 pinion angle. This means you need to know how far you are squatting or rising. This is where video is key. If you squat 2” set it up to compensate for that amount.
To come..
Chapter 3 – Shocks
Why you want adjustable shocks
Chapter 4 - Suspension Travel
How to increase front travel
How to make the back and front work together based on changing track conditions
Suspension limiter, why they might be used and their downfall
Chapter 5 – Trouble Shooting and tuning suggestions
It doesn’t hook right out of the hole, why?
Why does it hook for 3 feet and then blow the tires off?
It leaves sideways..
Chapter 6 - How/Why Video helps
Where to set the camera up
Helpfull hints to aid getting the most data for review during recording
What to look for
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-03-2009, 02:22 AM   #2
leftcoast66
leftcoast66's Avatar
Re: Suspension 101
I like this thread idea. I think it'll most definitely help for the people who haven't read up on this, and have some basis on our trucks. Nice work.
leftcoast66 is offline   Reply With Quote
Old 02-03-2009, 03:32 AM   #3
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: Suspension 101
hmmmm yep yep gonna need a pad an paper for this one.....Sweet
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 02-04-2009, 03:14 PM   #4
Super73
Super73's Avatar
Re: Suspension 101
Ok.. I think chapter 1 is finished.. I'll try and write up chapter 2 in a few days..
Old 02-04-2009, 03:40 PM   #5
71chevytruckguy
71chevytruckguy's Avatar
Re: Suspension 101
this is very helpful. cant wait to see the rest. keep up the good work. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-05-2009, 01:19 AM   #6
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Re: Suspension 101
This will be good to sticky. That way we can find it later.
Great write up. THANKS
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 02-05-2009, 05:10 PM   #7
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Re: Suspension 101
Yep, definitely needs a sticky on this one. Big thumbs up to Super73 for the write up and look forward to all the rest.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 02-05-2009, 11:08 PM   #8
AlienYouth
AlienYouth's Avatar
Re: Suspension 101
thanks a bunch, i'll probably be ordering parts as you go through the chapters, so you better be right! lol
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 02-06-2009, 01:13 AM   #9
Super73
Super73's Avatar
Re: Suspension 101
Originally Posted by hotrod 80 View Post
Using this formula i come up with a 240# coil ( which would go in a coil over shock ) as optimum if i replaced my torsion bars . My gut tells me 225 # .
I'm not saying these are optimum.. I'm simply using the formula to show you what you need as a min to hold the vehicle at the height you want based on your weight and length of spring. Coil overs have an advantage of using a lighter spring and turning the adjuster up to get the height you want..
You can have too much stored energy and not have enough shock to control it. Some of this I will cover in the coming chapters.
What is the static height of the coil? IE what length spring can go in to it?
What is your leverage ratio? Using a coilover, I'm assuming this is not the stock location..
What will the springs height be at ride height?
Do you know your unsprung weight? I'm assuming none factory suspension with a coil over set up.
Old 02-07-2009, 12:53 AM   #10
Super73
Super73's Avatar
Re: Suspension 101
I changed a little bit on the spreadsheet (Haven't uploaded it yet). It will tell you the spring rate you need based on length of spring in 1/4" steps, desired compressed height and unsprung weight.
Old 02-07-2009, 12:34 PM   #11
djracer
djracer's Avatar
Re: Suspension 101
great thread thanks Shaun.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-08-2009, 08:15 PM   #12
Old Yeller 1970
DON'T TREAD ON ME
Re: Suspension 101
Super73, I've been studying your work and plugging some numbers into the spread sheet and want to make sure I'm interpreting this correctly.
I have two 2" dropped Eibach springs that ride like a rock and don't let the truck lift a bit to transfer weight to the back. I measured the installed height and came up with 10" which I want to keep. I plugged the number into the spread sheet and the closest one is:
47195
Free Height 18
Rate 250
Coil Bind 6.875
Total front weight supported 3866
Weight Supported (each spring) 1933
Length at ride height 10.268
Amount compressed 7.732
Compression before bind 3.393
Desired Compressed Height 10
Difference 0.27
Ride height Change 0.51
So, If I understand what I'm doing I should order spring 47195 correct?
Also, the unsprung Eibach spring starts out a lot shorter and doesn't compress nearly as much as spring 47195, can I expect 47195 to ride more gently than the Eibach?
Old Yeller
Old 02-08-2009, 08:37 PM   #13
djracer
djracer's Avatar
Re: Suspension 101
What kind of truck weighs 3866 in the front.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-08-2009, 08:54 PM   #14
Old Yeller 1970
DON'T TREAD ON ME
Re: Suspension 101
I think it's the leverage weight on the springs not the actual truck weight.
Old Yeller
Old 02-08-2009, 10:42 PM   #15
Super73
Super73's Avatar
Re: Suspension 101
Can you tell me the front weight to double check..
If you did not change the yellow cells then it won't figure it out for you.
Old 02-08-2009, 11:23 PM   #16
Super73
Super73's Avatar
Re: Suspension 101
OOpppss.. Double post..
Old 02-09-2009, 01:35 AM   #17
Old Yeller 1970
DON'T TREAD ON ME
Re: Suspension 101
The only yellow cell I changed was the one for compressed height, changed from 9 to 10. I don't know the front end weight for certain although what you have is probably pretty close. I've got the truck in the shop finishing up some mods that will take a few more weeks before I can get it to the scales. I'll also be getting some new tires so I'll pull the wheels/tires and weigh them too.
Old Yeller
Old 02-09-2009, 02:18 AM   #18
Super73
Super73's Avatar
Re: Suspension 101
I would prefer you weigh the truck. But I think you are on the right track..
Old 02-09-2009, 09:33 AM   #19
Old Yeller 1970
DON'T TREAD ON ME
Re: Suspension 101
Yeah, I played with the weight input and could see how a few pounds either way might really affect the ride height so I'll definitely weigh it before committing to any parts.
Old Yeller
Old 02-10-2009, 01:20 AM   #20
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Re: Suspension 101
WOW, great job! Keep it up.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 03-02-2009, 02:58 PM   #21
Super73
Super73's Avatar
Re: Suspension 101
Bump for Chapter 2.. I was gone over the weekend and had some down time. I may have to go back and change a couple things, but I think it's pretty good right now.
Old 03-02-2009, 09:40 PM   #22
Rodms
Rodms's Avatar
Re: Suspension 101
Damn 73 when are you coming through town so you can take of all this cutting and measuring?
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 03-10-2009, 09:43 PM   #23
67BBC
67BBC's Avatar
Re: Suspension 101
Thanks for the great information, I am in the process of figuring out everything I am going to need to set up my trucks suspension. Still have not decided on rear axle yet, going to keep factory trailing arms and going to stuff hopefully 15x14 wheels under the wheel wells. How well will this work on a street/strip truck.
72 SNB Drag truck
67 Project (Sold)
85 4x4
11 Z71
67BBC is offline   Reply With Quote
Old 03-10-2009, 10:04 PM   #24
djracer
djracer's Avatar
Re: Suspension 101
you will have to tub the bed and it will work great!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-10-2009, 10:25 PM   #25
67BBC
67BBC's Avatar
Re: Suspension 101
its a snb as of right now. Guess my next step would be to figure out what rear axle and length to use and wheel backspace. Found a 9" that is 53.5 wide, not at home and don't have the measurements i would need to decide if it would even work.
72 SNB Drag truck
67 Project (Sold)
85 4x4
11 Z71
