Old 02-05-2009, 12:31 PM   #1
coolblue69chev
coolblue69chev's Avatar
Cool 69 C/10 Rear Roll Pan
Has anyone installed one of these and should I have to cut a notch for the recessed license plate inthe back cross plate to make it fit? If I do notch it for the license plate I think it will and then it will leave about 1/8 in gap on each side....Do you just tack weld these to hold in place? And there are also holes accross the top RIVITS,SHEETMETAL SCREWS,OR fill the holes in and WELD it?Need to install asap so I can primer and paint...Thanks for looking and for input....
coolblue69chev is offline   Reply With Quote
Old 02-05-2009, 12:51 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 69 C/10 Rear Roll Pan
Can't answer your question about the license plate issue but something to keep in mind, typically with a roll pan, the lower bolts that hold the tailgate hinge on get covered by this and are a PITA to remove. I had a guy show me this on his truck when I was thinking about doing a roll pan.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
67-72, body, build, custom, roll pan
