Old 02-05-2009, 11:30 PM   #1
GABE310
GABE310's Avatar
Questions on installing a 4l60e tranny????
A friend is selling me a 4l60e tranny that is complete out of a 2003 GMC Sierra.
What would I need to make it work in my 68 Chevy truck with 350 engine? Since my truck does not have all the electronics and computer. Do I have to buy a certain harness? Thanks
68 CHEVY SWB
95 HARLEY DAVIDSON NOSTALGIA
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
GABE310 is offline   Reply With Quote
Old 02-06-2009, 12:16 AM   #2
solidaxel
solidaxel's Avatar
Re: Questions on installing a 4l60e tranny????
Yes, and a stand alone computer to go with it let me know if you find a solution for under $1100.00 can you say Compu-shift
The rear transmission mount will be the easier part!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-06-2009, 07:19 PM   #3
Kid
Kid's Avatar
gotta agree with solidaxel, your better off with a 700R4 if your not going with a computer controlled / injected LSX motor.
Kid is offline   Reply With Quote
Old 02-06-2009, 08:07 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
check with these guys
http://www.bowtieoverdrives.com/index.shtml
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-07-2009, 12:54 AM   #5
GABE310
GABE310's Avatar
Looks like I will be selling the 4l60e tranny. And sticking with the 350trans.
68 CHEVY SWB
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
Old 02-07-2009, 09:42 AM   #6
Lextech
Lextech's Avatar
Even if you pieced together a factory harness, you would still need a TPS-Temp sensor-Tach and other inputs plus a custom tune on a factory PCM. I would still stick with an overdrive trans. 700R4 or a built 200R4.
Jeff
Lextech is offline   Reply With Quote
Old 02-08-2009, 01:36 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
With the proceeds from the 4L60E, go buy a 700R4. There's lots of people specifically looking for the 4L60E to replace the existing one in their car or truck. I have found recently that due to the tough economic times, many guys are selling off their parts, and I have seen lots of good 700R4s for sale. I just picked up a 700 (1991 model) that had a stock rebuild with about 2500 miles on it with a new convertor, TV cable, and cast aluminum torque convertor cover for $400. The guy had it in his V8 Vega, and he was converting the car to a manual trans. I installed it two weeks ago, and it works flawlessly.
The deals are out there. I have had great luck with Craigslist.
chevyrestoguy is offline   Reply With Quote
Old 02-12-2009, 01:27 PM   #8
kttrucks
kttrucks's Avatar
I put a 700R out of a Chevy conversion van in my '66. Used the Bowler lockup module/switch and it works great....brake pedal deactivates OD coverter lock and it a took an hour to install. I picked up the trans for $300 used......Chevyrestoguy is right! the deals are out there.
KT.
kttrucks is offline   Reply With Quote
