02-09-2009, 11:20 PM | #1 |
motor mounts
looking for some advice on the best way to mount my 632 its in a 70 short box thanks
02-10-2009, 12:14 AM | #2 |
Re: motor mounts
A motor plate would probably be the easiest and cleanest way.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
02-10-2009, 12:27 AM | #3 |
Re: motor mounts
do you know where i can find some pics on all to mount it to the frame thanks
02-10-2009, 10:09 AM | #4 |
Re: motor mounts
You need motor plates or at least a mid plate . That thing has alot of torque so you dont really want to hold it down with just the bosses on the block that could damage the block . You need to get a piece of 3/16" aluminium plate for the front and carve it out to fit . Then use some 1/8" steel on the frame rails to bolt it to . I would use TCI's mid plate / flexplate shield in the middle . They come oversise and are easy to fit . On the trans mount use a quality rubber mount . The tranny needs to be able to move a little to avoid breaking the case . You can click on my link but you might not be able to see much . I'm sure Kevins build thread would give you some idea of how to do it .
NHRA Super Street 469C It only runs 10.90 at 156 mph |
02-11-2009, 08:54 AM | #5 |
Re: motor mounts
here a few I dug up for you.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
02-12-2009, 03:03 AM | #6 |
Re: motor mounts
Motor looks great. Thing ought to be a beast.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
02-12-2009, 07:22 AM | #7 |
Re: motor mounts
that's the old one stay tuned for the new bullet!
02-12-2009, 05:24 PM | #8 |
Dr. Frankenstein
Re: motor mounts
Haha "Bullet"... More like Bazooka
I Wanna Go Fast!! |
02-12-2009, 06:51 PM | #9 |
Re: motor mounts
thanks for some ideas
