Old 02-16-2009, 11:10 PM   #1
mxer
mxer's Avatar
Cooling and A/C help
Can somone help me out with some ?s.My 56 has a camaro clip with a big block,approx 500 hp (not ran yet) theres really no room for a fan behind radiator,is ok to use a pusher fan and what size a/c cond should i use or does it matter.If the psher fan is running all the time shouldnt that be ok.This is the first time building a truck like this and want it right.
mxer is offline   Reply With Quote
Old 02-17-2009, 12:02 AM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: Cooling and A/C help
pushers work fine. see if you can fit two on there, or if not, use one big high flowing unit like a mark V fan. you can set it to turn on with a temp switch.
i run dual flex-a-lite 16 pushers on my 500 hp ford lightning, and the a/c blows nice and cold, and the truck doesn't overheat in traffic at 100*F outside.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
