Primer of choice
All the replacement panels are in and everything is aligned so now we are taking it apart to primer before body filler. What is the primer of choice? Epoxy, eurothane, etc. Brand?
Re: Primer of choice
The epoxy primer is some really good stuff, but if you use it make sure you have PLENTY of sand paper on hand. All the epoxy I have ever used loves to load the sand paper up!
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
... And if you are laying mud OVER the primer the epoxy is a good choice
and a few others
just a suggestion....you may want to check in the Paint and Body forum for lots of opinions/suggestions.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
one thing i learned about primer use something bright don't go black like i did. it became hard to see what i was doing unless i had a light. if i could do it again i would use a brighter color
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
Hey GT, I have found that the use of a guide coat helps a great deal on either light or dark primer. For black.. you can get a cheap can of white spray paint and lightly mist it over the area. Then you can see high and low spots when you sand and where needs to be sanded more.
#7 | |
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 02-19-2009 at 02:11 PM. |
roger than ben. my problem was working in the garage on areas under the dash i couln't see a thing with out the light.
GT
ohhhh IC
