Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-24-2009, 08:18 PM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Replacing my tired 283ci
Just got a older 350ci with 1:90/2:02 heads and flat top pistons on it.
Going to do a fresh rebuild. I have 3:08 gears on my 69 longbed with 15x10s in the back. Asking the members here for ideas on a build. Going for some mild to stout performance, but also want to be able to drive it everyday if I want or need to.
VDOG is offline   Reply With Quote
Old 02-24-2009, 08:45 PM   #2
Wild83C10
Wild83C10's Avatar
Re: Replacing my tired 283ci
whats your budget? Do you want to use the same heads? What tranny are you running?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-24-2009, 09:11 PM   #3
VDOG
Grand PooBaa Member
VDOG's Avatar
Keeping the same heads. Budget is around 2500 give or take.
I have a Th350 trans.
Old 02-27-2009, 09:15 PM   #4
VDOG
Grand PooBaa Member
VDOG's Avatar
After degreasing at the car wash. Now for the tear down.
Old 02-27-2009, 10:00 PM   #5
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
So is that budget all in the motor or is it For the Entire truck....alot you can get done with a 350 an about $2500
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 02-28-2009, 10:22 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
Just the engine. And that was on the high side. Dont want to spend that much. Truck budget, with the rust I have it will cost me 2500 just to remove the damage.
Old 02-28-2009, 11:10 PM   #7
ProStreet71
What casting heads do you have? Combustion chamber size? Most likely you will have the heads reworked. If so, you would be ahead of the game if you got you a set of vortecs for just a little more money than you will spend on reworking your current heads.
ProStreet71 is offline   Reply With Quote
Old 03-01-2009, 12:03 AM   #8
VDOG
Grand PooBaa Member
VDOG's Avatar
So my heads 190/202 will cost more than buying new Vortecs?
Old 03-01-2009, 07:29 AM   #9
ProStreet71
No, not saying cost more. But will cost you some performance unless they have some work done to them.
