I put summit vortec heads on my 350. When I went to swap over the sensors in the head they were the wrong size. The vortecs looks to have 3/8 and the stock head had 1/2 sensors. What is the best way to make this work? New sensor reccomendations? Its a 72, 350 with gauges. It has two sensors, driver front and passenger rear. Which is which? I think the driver front is for the gauge and the passenger is rear is for an idiot light. But there I go thinking again.
Re: which temp sensor
Im doing this now and ran into the same issue. Did you get it figured out? Heres what im going with. Both for a late 80's model 350.
WT357P for the light. WT359Z for the guage.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. Last edited by monte0185; 04-10-2009 at 04:45 PM. |
Apparently I am wrong after doing some research. Check out this thread.
http://67-72chevytrucks.com/vboard/s...63#post3250263
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Have someone cut your sensor down and rethread it for 3/8" npt. Thats about the only solution that works.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Jan 2009
I bought my heads from a junkyard and they came with sensors but I didn't use them, I put an aftermarket gauge cluster at the same time and I didn't hook up the factory gauges, I just used the mechanical one
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
I did some checking today and the actual sizes are 5/8 and 3/4. The original one is 3/4.
![]() Join Date: Dec 2008
I can turn these down and rethread them to 3/8 pipe. How much demand is out there for these?
