Old 03-05-2009, 12:03 AM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
removing steering column
ok, so i'm breaking down my '50 and can't seem to figure out how to get the column out. i have the gear box off, and i got the gear on the end of the column out, but how the hell do i get this plate off? w/o it off i cannot get it through the firewall.
I don't see any pins or screws holding it on. I started to go at it with a BFH, but didn't want to mess something up inside in case there's a pin i'm not seeing that needs to be pulled.
here's a pic of what i'm talking about.
btw, my build thread is in my sig if you want to check it out.
IvelDesigns is offline   Reply With Quote
Old 03-05-2009, 12:54 AM   #2
rstrick
Re: removing steering column
I seem to recall that it is a press fit and I don't remember any pins or anything. I think you can just knock it off the column housing.
rstrick is offline   Reply With Quote
Old 03-05-2009, 09:56 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
you take off the steering wheel and push it through the floor towards the ground.
dwcsr is offline   Reply With Quote
Old 03-05-2009, 01:49 PM   #4
sgtusmc
sgtusmc's Avatar
Sawzall and an aftermarket tilt column worked for me. I couldn't get it off either. So when in doubt, cut that f@cker out!
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 03-05-2009, 02:16 PM   #5
bretcopsey
x2
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
