Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-14-2009, 09:15 AM   #1
Wild83C10
Wild83C10's Avatar
Torque Arm
So hopefully within the next year I will be working on converting my rear suspension from a leaf spring w/caltracs to a trailing arm/watts link. My question is anyone run a torque arm with the trailing arms? I'm not sure if it's really necassary with the trailing arms. Anyone have any good opinions?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-16-2009, 03:37 AM   #2
Super73
Super73's Avatar
Re: Torque Arm
What would be your reason for using a TQ arm with the trailing arms?
All I see with the is the potential to bind the suspension. The TQ rm is used with a style of lower control arm that allows the pinion to rotate up. The TQ arm keeps the pinion from rotating up under acceleration. The fatory truck arms have mounting pads that are welded to the axle and once bolted down to a the arms, there is no way for them to rotate up.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-16-2009, 04:55 PM   #3
Wild83C10
Wild83C10's Avatar
Re: Torque Arm
I couldn't think of anyway that the rear could rotate with the trailing arms, but I thought I would ask those that use the truck arms.
turbo=
Old 03-16-2009, 07:36 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Re: Torque Arm
Couldn't have said it better. Look under a 82-02 F-Body and you will be able to see how a torque arm rear suspension works.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
