Old 03-14-2009, 09:59 PM   #1
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
Replacing Cab Floor - 72
I started the major metal work today on my 72 and discovered it has a lot more rust than anticipated.
Both of the front cab supports are destroyed and the cab floor is rusted through in places that are not part of the new patch panels or rockers.
Many places sell entire cab floor replacements for around $500 that would eliminate the rust spots I currently have. These cab floors also include the front and rear cab supports.
I have a few questions:
Has anyone ever used these replacement floors?
Would it be better for me to try and purchase a new cab rather than try and fix my existing cab? My cab does have factory air.
Is it possible to remove the existing cab floor without complete removing the cab from the frame and unbolting the firewall?
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 03-14-2009, 10:21 PM   #2
rob32472
Re: Replacing Cab Floor - 72
Check out my build project cod fish ebfabman is doing the cab work for me. You will have to unbolt and remove it or atleast raise it, but the firewal does not have to come off. Take a look it will definetly help. There are other threads as well
rob32472 is offline   Reply With Quote
Old 03-14-2009, 10:23 PM   #3
ebfabman
Yes its been done several times. Check out this build....btw, my brother lives in Norman.
http://67-72chevytrucks.com/vboard/s...d.php?t=317665
ebfabman is offline   Reply With Quote
Old 03-14-2009, 10:25 PM   #4
ebfabman
Hey rob, you have fast fingers.
Old 03-14-2009, 10:59 PM   #5
chevy29267truck
best thing is too find a cheap cab or truck with a good floor in it
chevy29267truck is offline   Reply With Quote
Old 03-15-2009, 12:14 AM   #6
cedorris
cedorris's Avatar
Where would you recommend looking for a cab floor replacement panel? LMC has them for around $500 delivered.
What kind of coating do you recommend for the bottom of the new floor?
-Clayton
Old 03-15-2009, 01:13 AM   #7
chevy29267truck
ok go on craigslist.org than go too oklahoma city also you can try www.car-parts.com or make a road trip too arkansas or texas
Old 03-15-2009, 03:44 PM   #8
lchall
I was kinda in the same boat as you with my floor. I started cutting away for a piece-by-piece repair and kept cutting more and more metal away. I decided to go with the one-piece floor instead. I would definitely make sure to get the floor with the braces installed. It's not that much more and saves a ton of work. I got mine at GMCPaul's for $420 + shipping.
I pretty much followed this how-to by jlaird and it was dead on. Msgross has some real good information in his build thread as well.
http://67-72chevytrucks.com/vboard/s...+floor+install
http://67-72chevytrucks.com/vboard/s...58#post2194858
The install is pretty straight forward, but I would think would be difficult without removing the cab. I welded in some bracing and did the repair with the cab on it's back. I needed to/am in the process of replacing the rockers and cab corners and with those removed I think it makes it a lot easier to work with. Then you only have the firewall and back of the cab spot welds to deal with.
Overall the floor is a fantastic piece that pretty much bolts/welds in. There are about 30 or so spot welds at the firewall and about the same on the back panel. The main floor supports have 10-12 spot welds/support. Since I didn't have cab corners or rockers thats about all there is. There are the bolts for the A/B pillars, but those seemed to line right up for me.
I only had a few very minor issues with the floor and all of them had to do with the firewall flange area. None are a big deal at all. I had to make a couple of pie cuts at the outer edges of the firewall flange and at the gas pedal area. I also made a small cut at each side of the bend for the transmission hump. The curve of the floor wasn't quite sharp enough match. The last thing was the angle of the flange. I had to hammer/dolly the flange somewhat to get it to match the angle of the firewall. Not a big deal at all, but it just kinda sucks when you get a big floor all up and aligned and then have to take it all back out to get do the work on the angle.
Here's a few pics of what I did.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 03-15-2009, 04:38 PM   #9
72armyswbtruck
72armyswbtruck's Avatar
Now those are some awesome pics.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-15-2009, 10:54 PM   #10
Ram-Man
Ram-Man's Avatar
I wouldnt mess around with trying to piece it together. IMO the full floor with supports is the only way to go. Here is mine
http://67-72chevytrucks.com/vboard/s...ighlight=floor
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 03-16-2009, 12:00 PM   #11
cedorris
cedorris's Avatar
I found a cab that is exactly like mine that the owner claims to be rust free except the passenger side rocker.
It has been blasted and primered.
He is asking $800.
What would you guys recommend? Am I better off going with replacing my own floor and rockers or going with that $800 cab. It seems a bit steep, but I really don't know much about how these things are priced.
Here are some pics of the Cab: http://www.flickr.com/photos/cedorri...7615313997557/
-Clayton
Old 03-16-2009, 01:12 PM   #12
Joe67
67 is sold
That would be one expensive option
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-16-2009, 01:13 PM   #13
Joe67
67 is sold
Great reply! That is what this forum is all about
Old 03-16-2009, 01:27 PM   #14
tim21391
tim21391's Avatar
check out my build thread
and check out 88jrfan's build thread... him and i's truck's floor were patched
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-16-2009, 02:23 PM   #15
cedorris
cedorris's Avatar
Here is a picture of the area that is giving me fits
See how the rusted through area creeps up past where the rocker panel covers?
Is there a way to patch this area? My front cab supports are also shot.
-Clayton
Old 03-16-2009, 04:14 PM   #16
rob32472
there is a patch panel that covers 4 inches past the rocker all of the vendors have them.
Old 03-16-2009, 11:20 PM   #17
tim21391
tim21391's Avatar
its called the outer floor extension piece it runs from fire wall to rear of cab.. its about $100 some.. but its worth it.. used it on both sides of my truck..you cant go wrong with it..
Old 03-17-2009, 06:42 AM   #18
67slammer
67slammer's Avatar
i bought a 1 pc floor from tri pro automotive. it fit like a glove and its nice to buy from another board member. it was about a 4 hour project start to finish.
67slammer is offline   Reply With Quote
Old 03-17-2009, 08:47 AM   #19
cedorris
cedorris's Avatar
Can you send me a link in a private message to the store where you ordered it?
-Clayton
72 chevy, body work, cab, cab floor
