03-18-2009, 11:28 AM | #1 |
Converting diesel to gas.
I have a chance to pickup a 84 6.2 diesel with a great body and a non running engine. What would be involved it changing it over to a 350 small block?
Thanks Robert |
03-18-2009, 06:54 PM | #2 |
Robert Olson Transport
Re: Converting diesel to gas.
anyone?
03-18-2009, 07:21 PM | #3 |
18 Till I Die
I dont know if the trannys match up. Might have to change it as well. Its been awhile since I looked into that.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
03-18-2009, 07:24 PM | #4 |
profeshinaly unimployed
my truck use to be a diesle and is now a gasser...i know one thing for shure u dont need new gauges cuz mine still says diesel
"having mud flaps is like asking for a smaller trophy" |
03-18-2009, 08:05 PM | #5 |
www.73-87chevytrucks.com
Exhaust and clean fuel tanks/lines.
Tranny bolts up same. Some of the wiring won't be there, but it can be done....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-18-2009, 09:04 PM | #6 |
Another Day, Another Dollar
doesn't te harness have to be changed?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
03-18-2009, 09:58 PM | #7 |
Location: Where I come from, it's cornbread and chicken...
the engine harness - yes...others - no...
03-18-2009, 10:21 PM | #8 |
Yes, the transmission will bolt up- it's the same pattern as a sbc. I'm pretty sure the motor mounts are the same too. So setting the gasser in should be cake.
The wiring- you don't necessarily have to change it unless you are just trying to clean it up. Both engines alternator and starter wires would be the same, as they perform the same functions. Oil pressure gauges read pressure- they don't care what kind of engine is producing the pressure. Same with the temperature gauge. So that pretty much leaves power to the coil, which if you're using a standard HEI, it needs a 12v key-on source. The diesel harness provides keyed-on 12 volts at the injection pump, so there's your wire.
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels Who needs a car when they make crew cab trucks? |
03-18-2009, 10:36 PM | #9 |
Oilfield Trash
You will also have to reuse the diesel's power steering pump so the hydroboost will still work properly.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
03-19-2009, 12:29 AM | #10 |
Resident of Here
Why would you change it to gas?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
03-19-2009, 05:05 AM | #11 |
Rottenwood Garage Member
A non running GM diesel........go figure! Look into the rear end also.....a lot of them have pretty low gearing. Engine harness YES. The guages will be fine.....Some folks say change the radiator also but we have done this swap a few times and never changed them.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
03-19-2009, 05:06 AM | #12 |
03-19-2009, 07:30 AM | #13 |
the radiator is actually larger than a gas radiator...well mine is anyways...
Chuck. |
03-19-2009, 07:37 AM | #14 |
yeah don't change the radiator my engine stays extra cool cuz the stock diesel radiator
03-19-2009, 08:04 AM | #15 |
It has always been my understanding that you did not mix used coolant or coolant system parts from a diesel with a gas burner, but as mentioned above.....I have done it with no adverse reaction that I could see.
03-19-2009, 08:28 AM | #16 |
The only thing not mentioned yet is different valving inside the trans between gas and diesel. It affects when the trans shifts and is specificaly tailored to one or the other as far as I know.
1986 Chevy 3/4 Ton 4X4 |
03-19-2009, 09:31 PM | #17 |
Resident of Here
72Freak, what are you talking about? 6.2 diesels are the best GM diesels ever built. Also, what is so funny about my question? I dont see the logic in converting from a 6.2 diesel to a gasser. (No offense Robert8096)
03-20-2009, 01:05 AM | #18 |
Professional Grade
I'm a major fan of the 6.2L diesels too! Mine is turbocharged and will take any 454 from the mid 80s on a very good run for it's money, whilst getting 20+ mpg doing it too!
That said, as mentioned above, making the swap is not particularly difficult. The 350 will bolt directly in place of the diesel. Fuel system will need a flush to clear the diesel out, govenor and torque converter on the trans both need to be changed for the gasoline versions. The wiring would be easiest done if you were to get a gasoline engine harness. It bolts right up to the firewall junction block without any modifications.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
03-20-2009, 07:12 AM | #19 |
I would keep it a diesel if the engine wasn't shot. I have a good 350/350 combo that I could put in it. I would like to use the transmission that is in it because it has a 4 speed automatic. I like the idea that it has the hydrobost braking system and that most of the accessories work. He says the AC works but that is hard to confirm because it does not run. The only problem with the body is someone took sheetmetal screws and used them to hold on the stick on trim.
03-20-2009, 09:39 AM | #20 | |
My years of experience with and opinion of(you know what they say about opinions) on the Duramax predecessors are well documented on this forum. Search key word "boat anchor". This thread will turn into yet another GM, Cummins, Powerstroke diesel thread and we reallly dont need any more of them cluttering up the forum.Agree to disagree? I am a firm supporter of transplanting gas motors when the GM diesels start to give you problems....again.....OPINION based on past experiences only.
03-20-2009, 02:14 PM | #21 | |
Resident of Here
03-20-2009, 03:55 PM | #22 |
Thanks for all the info. Please don't turn this into who's diesel engine is better or gas VS diesel.
Thanks Robert |
03-20-2009, 06:15 PM | #23 | |
Bottom line...if you want to convert to gas...follow the advice given above and convert to gas......If you want to stick with the original GM diesel do it. Do your research, take your time and enjoy it. Learn all you can about whatever you decide to do! Diesel mods, tweeking injector pumps, or a nice punched out 5.7 gas. Its all turning wrenches and having fun.
04-04-2009, 05:49 AM | #24 |
i am doing this same swap the only thing im not sure is to go to a brake booster instead of the hydroboost set up would i have to change the stearing box or can i still use the stock one
thanks |
