Old 04-04-2009, 12:55 PM   #1
OrrieG
OrrieG's Avatar
Fender and body bolt question
I am getting close to doing final fit assembly before painting.
Are the fender and body bolts (radiator shroud, etc.) with flat area under the bolt head designed as an interference fit? They are assembled without lock washers so I assume they are to combat loosening from vibration.
I need to start buying the new bolts for final assembly and need to justify the expense of the "correct" fasteners vs. ones I can get locally. Thanks Patrick
OrrieG is offline   Reply With Quote
Old 04-04-2009, 08:19 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Fender and body bolt question
None of the fasteners on these trucks are an interference fit, which puts your bolt and hole tolerances in the thousandths. Most of the holes are considered a class 3 fit, which is roughly a .250 diameter bolt in a .281 diameter hole.
I consider the fastener kits a good investment. I bought a Totally Stainless kit for my 69, everything was labeled for where they went. They were the correct length and diameter, and far cheaper than buying the bolts from a hardware store. You also get the correct lockwashers.
I bought one kit that was from a foreign maker, but will not repeat that mistake. I had problems and showed the results to a metallurgist at work. We determined that the bolts had not been heat treated.
If you go with a stainless bolt kit, all of the bolts need to have either a thread-locking compound or anti-seize compound to prevent thread galling, which is where the metal of the bolt and nut threads become one, making it impossible to remove the bolt. I also will not put a stainless bolt together with a stainless nut, which will gall even with a compound.
My experience comes from engineering at Boeing, where I did a lot of work on B-52 structure repair, fastener design and corrosion control.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-04-2009, 10:09 PM   #3
OrrieG
OrrieG's Avatar
Fred - I guess I used the wrong term, but you answered the question. I assume on the fender type bolts then that the fender metal itself and the capture nuts act as a lock washer? Good tip on the anti-seize compound, thanks. Who did you get the kit from that you liked?
Old 04-04-2009, 10:11 PM   #4
britnjc
britnjc's Avatar
who sells a stainless bolt kit for ad trucks?
britnjc is offline   Reply With Quote
Old 04-05-2009, 02:12 AM   #5
mylow53
mylow53's Avatar
i've heard of guys buying bulk stainless steel at a swap meet like pomona. it would be a bunch cheeper than the hardware store. i've spent near 300 on bolts over the last year and i still need more!
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-05-2009, 10:15 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Originally Posted by OrrieG View Post
Fred - I assume on the fender type bolts then that the fender metal itself and the capture nuts act as a lock washer? Good tip on the anti-seize compound, thanks. Who did you get the kit from that you liked?
Most of the sheet metal bolts have either a serrated flange or a lockwasher permanently attached bust below the bolt head. This is the locking device. GM didn't use a locking type nutplate much on these trucks. They cost more and took more time to install.
I am a big believer in blue loctite whenever possible. It seals the threads from corrosion.
The bolt kit for my 69 came from www.gmcpauls.com. His on-line catalog doesn't list for the AD truck, but that doesn't mean he doesn't carry them. These kits are from www.totallystainless.com, who now sell direct. www.americanclassic.com shows kits that look identical to the totally stainless packaging. I would think they would tell you if you called.
Fred
Old 04-05-2009, 01:29 PM   #7
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Amen on the blue loctite.
The best bolt kit seems to come from Totally Stainless.
http://www.totallystainless.com/totally.html
Fred, you say you never use a stainless nut with a stainless bolt because of the galling of the threads; do you use an anti-seize material when the nut is not stainless?
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 04-05-2009, 09:00 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
I use blue loctite most of the time. Otherwise grab the anti-seize. There are two issues. Galling can occur between stainless and alloy steel, but galvanic corrosion is a bigger issue. That's where dis-similar metal form an electric field and corrosion sets in. The result is usually cracks forming in the threads.
Fred
Old 04-06-2009, 07:16 AM   #9
renegade6
Does anyone make a good standard (not stainless) kit?
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 04-06-2009, 09:15 AM   #10
BIG CHEVY 3600
Most vendors carry them.
Abraham Lincoln
Old 04-06-2009, 10:02 AM   #11
robin58
Brother's lists various stainless bolt kits for AD trucks.
robin58 is offline   Reply With Quote
