hanging pedals and steering colom for a 56 ???
i have been searching around to find which under dash clutch and brake pedals you guys have been swaping in, the only real swap i have see was a brake pedal only using the hanger from a camaro that the guy got the clip from. i need to get the brake stuff swapped at the minimum and the clutch would be nice to do as well.
i also notice that the 1/2t truck use a slightly different steering setup than my 2t does, reguardless the steering box need to move aswell and the hamb write up did show how to seperate the colom and box and if the stock box is reuseable or if you have to use the new style sag boxes. the steering colom also sits in the 2t lower and closer to the driver so i would want to push it up closer to the dash while im at it. pics shortly. |
Re: hanging pedals and steering colom for a 56 ???
![]() Join Date: Nov 2008
I've read about using the setup from a late 80s Suburban. I grabbed a set from a 87 1 ton with a hydraulic clutch but, haven't installed it yet.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
an s-10 setup will work well also
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
