04-06-2009, 06:40 PM | #1 |
camaro clip....its been a lone time
hey guys its been a lone time ,i been around working hard and going tru some ruff times ,i got in to trouble got my license suspended and i had to spend my ( mustang 2 sus money) in lawyer ..i got frustrated and wanted to sell the truck but decided not to sell it and go forward with the project so checkng old school newspaper i saw the camaro front sub for $200 an went for it, so i got it today.....no money for mustang to, so i got the camaro sub..two weeks from now i would go to english town for a car show, hopefully i will get all the parts for the sub i need.its in good condition...
04-06-2009, 06:46 PM | #2 |
Re: camaro clip....its been a lone time
i went to upstate ny for this freeking camaro front end....35min drive thanks to my (gps) an my friends ,this ****ing frame is heavy
04-06-2009, 06:49 PM | #3 |
im about to order that video (dvd) from no limit .to have some idea on the welding..
04-06-2009, 06:55 PM | #4 | |
Tripple Five Fanatic
Tri5 |
04-06-2009, 07:32 PM | #5 |
to late ...i will get the video by friday its ok i just need ideas ,i spoke to the guy over in no limit and they going to help me 2...its not a big thingi read the (hamb)site like 10times its ok i get it done
04-06-2009, 07:34 PM | #6 |
the guy told me that the video was made in the 80s...20 some years ago
04-06-2009, 10:23 PM | #7 |
polishing a turd
it gives you a good idea on what needs to be done, but it is far from step by step.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
04-07-2009, 08:40 AM | #8 |
It is a shame that video is not updated and more detailed. There are several key issues it does not address very well.
It would be a great help to the hobby if they or someone else refined this process. |
04-07-2009, 10:40 AM | #9 |
Hey Stan3018 I used the No Limit video as well, worked out well. Good luck with your install and keep us posted with pics!
04-07-2009, 03:51 PM | #10 |
When I did my 56 I layed the sub under my frame ,1st bolted it in place then welded and boxed it. This way my motor and tranny mounts were right on. Also might want to think about moving the clip foward to center thr front wheels.
04-07-2009, 10:04 PM | #11 | |
04-08-2009, 07:18 AM | #12 |
hey bro question? Igot my camaro frame but i dont see any shocks does the camaro sub carries shocks .
04-08-2009, 07:53 AM | #13 |
They go inside the springs
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
04-08-2009, 08:46 PM | #14 |
04-09-2009, 01:17 AM | #15 |
One one my buddies just hung another one of those stubs (actually a trans am) under a similar truck.
Here are some photos that I posted before. http://s173.photobucket.com/albums/w...pu%20subframe/ I've had two vehicles that were subframed. My 48 and the 51 Merc coupe that I owned for 32 years. This I can offer. Find out the stock ride height of the model of car the subframe came out of and set the crossmember at that height. This usually takes crawling under a friends Camaro and measuring from the bottom of the crossmember to the ground. Make sure it is a stock height car. You want to block the subframe up at that height with the ends of the subframe rails level with the floor. When my autoshop students and I did my 51 Merc we set the car at the exact static height I wanted to run it by making wood blocks to place under the frame. We set the frame rails level front to rear. At this time any rake isn't important but you want the stub to be square and level with the stock frame. All else I can say is measure, measure, measure and make serious use of your level. Last edited by mr48chev; 04-09-2009 at 01:21 AM. |
04-09-2009, 01:30 AM | #16 |
The link to the article on the H.A.M.B.
http://www.jalopyjournal.com/forum/s...d.php?t=148978 |
04-09-2009, 07:17 AM | #17 | |
04-09-2009, 07:20 AM | #18 | |
