Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-27-2009, 10:18 PM   #1
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
tail light wiring plug
on my 72 blazer i am in the middle of installing a summit wiring harness, i decided that since i dont have new lights for the rear i was just going to stop the wires for now at the old harness plug on the drivers side of the gas tank. i can tell what color the wires are. i need to know when i am looking at the plug on that is stuck in the frame, there are 4 wires going into the plug if the yellow stripe wire is on the left side, going left to right what wires go where. i found a wiring diagram but it doesnt help. cause like i said i cant tell what color it used to be.
thank you
72blazer_mud_bogger is offline   Reply With Quote
Old 05-23-2009, 11:14 AM   #2
tires2burn
tires2burn's Avatar
Re: tail light wiring plug
If you wet a rag with some lacquer thinner and wipe the wires gently it will clean them like brand new.
tires2burn is offline   Reply With Quote
harness, tail lights, wiring
