04-29-2009, 09:02 PM | #1 |
Battery Junction Block
I am looking for pictures and information on the junction block located near the battery. My truck doesn't seem to have one at the moment and I'd like to try and find one.
Does anyone have pictures of it or it's location? Or do you have a link on where to get one? Thanks. THis is what I dug up so far: If that it on the left? if so, is that stock? same here
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
04-29-2009, 09:35 PM | #2 |
Middle-aged Curmudgeon
Re: Battery Junction Block
Yes and yes.
I got a new one from GMCPauls. It's not exactly like the original, but pretty darned close. Looks like the one in your second picture may be an aftermarket. The one in the first picture is an original.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 Last edited by Lugnut64052; 04-29-2009 at 09:37 PM. |
04-30-2009, 08:09 AM | #3 |
ok, so looking at it, it's just a single post connection?
Also, the fusable link, what size and rating should that be that connects it to the battery? Could an inline fuse be used instead?
04-30-2009, 11:02 AM | #4 |
Yes, it's just a single threaded stud, and all your connectors stack onto it.
The fusible link should be four wire sizes smaller than the wire it is protecting and around six inches long, so on the factory wiring it should be 16 gauge. Having said that, I see on this diagram that the fusible link is six sizes smaller, so somewhere around in there. You might check out this page over at MAD Electrical for more information. If I were going to put a fuse in, I'd use one of those bigger, blade type fuses like you see in later cars and match it to your alternator output.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
04-30-2009, 11:17 AM | #5 |
Thanks. I will have to look into getting a post and some fusable link to get mine going.
Another question, in this picture, the little box to the right of the heater box on the firewall with the pins coming out, is this the fuse shown in the above picture, or is this something else? Also, how does it get connected if so? ...........................................| ...........................................| ...........................................V Thanks
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 Last edited by JimmyFloyd; 04-30-2009 at 11:19 AM. |
04-30-2009, 12:00 PM | #6 |
No. that's a relay.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
04-30-2009, 05:11 PM | #7 |
Would this work as a junction block?
04-30-2009, 06:22 PM | #8 |
chevelito
this one's more like it...but there's got to be a cheaper alternative.
http://shop.oreillyauto.com/ProductD...goryCode=4017D
New deadline...when my son can drive. Aloha from Honolulu, HI |
03-07-2013, 07:25 PM | #9 |
K5drive
LMC has that item on page 157 in there catalog bottom right on the page "follow link
I'm try to buy one but they won't ship to Canada without the $50 brokerage fee .Dicks !! So was hoping someone here might be able to help .... Help http://www.lmctruck.com/icatalog/cb/full.aspx?Page=157 Posted via Mobile Device |
03-07-2013, 08:35 PM | #10 |
ship it to point roberts.
to the op, make your own.. thats what i did.. i think the studs were like 5 each from summit.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
11-27-2014, 12:35 AM | #11 | |
11-27-2014, 02:57 AM | #12 |
Old member
Here is the one I found and if it's not exact it's as close as you will find I bet.
http://www.bowtiebits.com/store/stor...ategory_ID=100
11-27-2014, 03:03 AM | #13 |
Old member
Yes it would work and also give you 6 added fuses. I wouldn't want it out by the battery though. I installed mine off the unfused circuit on the fuse block under the dash so that it powers up when I turn the key. The heavy red wire on the stud powers everything.
12-08-2014, 04:07 PM | #14 |
If you're looking for an under hood junction with a cover, I have some in stock with and w/out a fused protection. They are similar to the 90's GM style except these have snap-to-lock tabs on both ends-they aren't weatherproof, only splash resistant.
