![]() Join Date: Jul 2007
71 Longhorn BBC, AC, PS, PB parting out
![]() My paypal is s_nova69@yahoo.com The body is not great but most of the good stuff is there. I twas an auto but some one put a 4spd. Does have AT cross member but a hole in the high hump cover. No response in 24 hrs means it goes to next in line so stay ahead of the curve. ALL PRICES DO NOT INCLUDE SHIPPING AND ONLY CARGED WHAT IT COSTS!! The list starts here: AC brackets $265 power str brkts $100, alt brkts $100, AC control $50, BBC fan shroud $40 (has small missing piece on upper corner), Auto non tilt column-no shft lever $50, BBC engine 402 Runs good drove it home no problem (no smoke at all) $400 shipping poss, AC evap box (good shape) $50 BBC engine stands and brakets $150 BBC air cleaner and spacer $30 BBC air pulleys $60 AT cross member $50 drive lines $40 Interior ac compnents-list what ya need booster and porp valve $30 Rolling chassis C30 Longhorn $150 AT kick down switch and wiring exhaust manifolds $60 If you are local I will be taking what is not sold to the Thanksgiving point swap on May 15-16 so bring your wagons. ![]() Thanks a ton and those picts will be up soon but I might need advice on how to do that since I never have listed stuff here before. I will do my best to keep up with everyone. |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: 71 Longhorn BBC, AC, PS, PB parting out
Any cracks or anything else wrong with the A/C box? Also, does it have a high hump trans tunnel? Shipping to Wake Forest NC 27587 please
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Moderator
![]() Join Date: May 2007
Do you have the heat shield/riser tube that attaches to the driver side exhaust manifold and air cleaner? If so, price shipped to 92503. Thanks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Resident Curmudgeon
![]() Join Date: Dec 1999
I'll take the auto kickdown switch and wiring pending price and pics/description of condition.
Also air cleaner and spacer Thanks
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all Last edited by CPNE; 05-01-2009 at 01:55 PM. |
the power brake booster and prop valve, would it work on a 69 C20? any pics?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
Always on the hunt...
![]() Join Date: Sep 2006
BBC air pulleys $60 - I will take them pending a picture or confirmation of stamped p/n's, the one water pump pulley and the two on the crank are all stamped. Thanks
![]() (wp pulley p/n should end in 5648 or 7789, the inner crank pulley p/n should end in 4414 or 4418 and the outer crank p/s add on pulley p/n should end in 5525) |
Put me inline for the kick down switch and wireing.
Roadtrip!
![]() Join Date: Feb 2003
Any emblems and seatbelts?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Ok here are the picts from yesterday of parts etc.
some more
more again
Here are the picts from yesterday as promised.
1972 Super Cheyenne AC box is good. the high hump has a hole for 4spd if you want it let me know. leddzepp Sorry no heat shield or tube. I have another bbc super that is missing 2 CPNE kick dwn & wiring yours picts listed today. will get it off today. Devil Pup No a 69 c20 has frnt drums so the booster and prop not work 4 u Classic Bowties pulleys are original and will have picts later today 4u 402GMC second in line for kick down switch too much stuff seat belts are NG really and picts listed or emblems today if u want them. The green longhorn bed is from another truck and I could sell its mate (ie pass side) if someone wants it for $100 The chrome on it is in the same shape and can get picts of that another day if interested. It is raining today but I will be up there pulling that apart anyway. I will get you shipping prices as soon as I can weigh stuff and box it some time this week. Thanks to all and good hunting. |
#13 |
some more
#14 |
and more
#15 |
![]() Join Date: Apr 2003
how much for the clutch rod, Z bar , and the ball that mounts to the engine ? Thanks Woody
#16 |
Roadtrip!
Let me know a price for any emblems and any seatbelts that may be useable yet. Shipping would be to 55744. Thanks, Eric
How are the hubcaps?
#17 |
Middle-aged Curmudgeon
I could use all the underdash A/C stuff; the parts marked 11 through 15. How much for all of it to 64052?
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
#18 |
![]() Join Date: May 2008
how much for door panels? steering column?
#19 |
Moderator
![]() Join Date: Jun 2008
Interested in the bed molding. I need both uppers and the bottom passenger side near the cab. Could you post some more close ups and shipping to 95357?
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 05-02-2009 at 05:03 PM. |
#20 |
Is it a Dana 60 in the rear?
If so how much for the center caps shipped to zip 30016? I guess the wheels would be too much to ship??? AJ |
#21 |
Resident Curmudgeon
I will take the kickdown switch and wiring. Let me know shiping to 03580. I assume a flate rate USPS package would work. I will pass on the air cleaner, thanks.
Please PM me the total cost of kickdown switch/wiring including shipping.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#22 |
I will pass on the trans tunnel and A/C box. Thanks though.
#23 |
![]() Join Date: Nov 2008
Do you have both Custom Camper/30 emblems and if so what condition and how much shipped to 87123? Thanks, Paul
#24 |
![]() Join Date: Jan 2009
Does it have aux fuel switch on the dash? If so, how much shipped to 32904?
#25 |
how much for ps pump, resevoir, brackets, & lines?
