05-17-2009, 08:46 PM | #1 |
any block differences between TBI and Vortec
Hi I have a 1996 burb with a seized Vortec 454. I do have a engine block from a 94 burb. Are the blocks the same? I was told that they are and I don't even need to move the heads because there were no "vortec" heads on the 454....is this true? If so all I need to do is move over the mounts and intake parts. Any more insite on this? Or is it cut and dry. I need to know.
05-17-2009, 11:33 PM | #2 |
Re: any block differences between TBI and Vortec
Mind you I'm no vortec expert, but my understanding is that the only difference is cylinderhead volume and intake so it sounds pretty straight forward to me
05-18-2009, 06:02 AM | #3 |
With small blocks, a TBI enigine has a flat tappet cam and a Vortec uses a hydraulic roller. The bosses might be in the TBI block for the roller lifter retainers, but the machining is not done.
Tim |
05-18-2009, 01:03 PM | #4 |
Yeah the Vortec BBC is a roller motor and the Vortec heads are about 1,000 times better than the tbi peanut port heads, but if you are going to junk the Vortec motor I'll buy it, or the heads??!! You can put the 94 right in place, and it should work OK, but performance may suffer a bit.
05-19-2009, 11:39 PM | #5 |
motor exploder
I do know for sure, but the blocks should be the same. All the '91-up BBC's are the Mark V style (roller cam is the main difference, so are the water passages on the heads from what I understand) The 'Vortec' heads from the '97 will work on the '94, and I would use them if I were you. it will bump the compression up on that '94 at least 1 full point, and offers much better ports.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-21-2009, 09:35 AM | #6 | ||
Anthony |
05-21-2009, 10:57 AM | #7 |
motor exploder
'91 may have been a split year, but that '94 will most likely be a Mark V. Guess you could just look at the back of the motor for the 1 pc rear main, if it's already out of the vehicle??
