Old 05-21-2009, 10:31 AM   #1
1bcooper
Lightbulb 99 Suburban Transmision Swap
99 Chv C1500, 4L60E transmission with cooler/towing, etc. I have blown three transmisisons.
*Can you replace the 4L60E with the heavier 4L80E?
Will the computer still work?
I am towing a 6000# Airstream.
1bcooper is offline   Reply With Quote
Old 05-21-2009, 09:48 PM   #2
bwood
bwood's Avatar
Re: 99 Suburban Transmision Swap
I believe the 4L80E is longer and will require the crossmember to be moved back and a custom driveshaft. Also the ECM will need to be reprogrammed for the 4L80E as the internal gear ratios are different and it wouldn't shift correctly. What has killed you other transmissions? I wouldn't think a 6k# camper would do it. I know a few guys pulling more and have had no issues. What is your gear ratio? If it is kinda low (numerically low), like 3.42 or 3.23, you may concider a gear swap to something like 3.73. This will negatively affect your mileage when you are not pulling, but will take some strain off the trans. Are you using your tow haul buton at the end of the shifter? How fast do you drive while pulling?
BTW, welcome to the board.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 05-29-2009, 08:37 AM   #3
1bcooper
I have a 3:42 rear end. I tow 60mph.
Old 05-29-2009, 12:53 PM   #4
jgreene0717
Jason
jgreene0717's Avatar
Do you pull it in overdrive or do you put the transmission in 3rd gear. If it where me I would not pull at 60 mph in overdrive.
jgreene0717 is offline   Reply With Quote
Old 05-29-2009, 04:03 PM   #5
1bcooper
I do both. If I am on a real flat interstate, etc. I will keep it in Drive. Most of the time, however, I am pulling in 3.
Old 05-29-2009, 11:22 PM   #6
bwood
bwood's Avatar
How many miles on the trans? Before I went to the trouble to convert over to the 80E, I would look into beefed up 60E made for towing. This way its a direct bolt in. I also have 3:42 in my truck and it is pain to pull much more than my bike trailer. My friend has the same truck as mine with the V6/auto with 4.10s (I think) and it will pull better than mine. Of course mileage isn't as good. We used his truck and my trailer while I was putting a new engine in mine. It does sit higher in the RPMs, but it gets down the road without excessive shifting with it in 3rd/OD. He pulls like you do, OD on flat ground and 3rd everywhere else.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 05-29-2009, 11:33 PM   #7
Captainfab
60-66 Nut
The wiring harness for the 4L80E is different than the 4L60E harness. Plus as was already posted the PCM will need to be reflashed.
4l60e, 4l80e
