Air Compressor
I have to get a new air compressor. I'm using a 30 gal. & it's worked to death.
I see a lot of 60 gal. on Craigslist (they're in my price range) and some 80 gal. (a little too expensive). What do you guys use? Will a 60 gal. run air tools w/o continuously turning on & off? |
#2 | |
Re: Air Compressor
It depends upon what you call "air tools". Some are much greater air-hogs than others and some are just used it short bursts, where others are more "continuous".
Impact guns and air ratchets are usually less hoggish. Sanders, die grinders and spray guns will tax a "medium sized" compressor. The most important factors in compressors are CFM rating and duty cycle. (How much air it can pump and how long the motor can run safely) What it comes down to is pretty simple. A pump that can flow/compress more air in less time takes a more powerful motor to turn it. The Duty Cycle is usually expressed as a percentage %. That precentage is the amount of time per hour that the motor can run w/o having "off time" to cool down. This is where people get into trouble by trying to "add" extra tanks to their system. Yes, they get more total stored air volume...but the motor has to run too long to fill it up. This is hard on the motor and it creates a lot of heat in the air itself. When this hot air cools the humidity in the air condenses back into water....which sits in the tank, or blows through your tools, or onto your project. Not cool.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Blaze-Air
Re: Air Compressor
Good explanation Longhair. I need a new compressor if I want to learn how to paint.
Re: Air Compressor
Thanks longhair. But I will have read, and re-read.....AND RE-READ your explanation in order to my brain to grasp that! I really appreciate it.
Re: Air Compressor
I have a 5HP 2-stage ingersol rand and it gets the job done. I would buy the largest one you can afford. It always seems that down the road a ways we always need more power. BIGGER IS BETTER.
blood type; Retumbo
Re: Air Compressor
as for quality, the heavier the better. avoid the oil free ones like the plague. they are designed for occasional use only. ie: a tire every other month or so, or 5 lugs nuts twice a year.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Air Compressor
Just a little input here...
I run an Ingersoll Rand unit in my powdercoating shop. I flat beat the tar out of that thing every day. I mean, the thing will run maybe 5 plus hours per day. It's a 100 percent duty cycle unit, so it's supposed to be okay with that. Anyway, a few weeks ago, it blew a head gasket. I called the 1-800 help number on the sticker and talked to an honest to God English speaking woman in the good old U S of A. She helped me find the part numbers I needed for the gaskets and then switched me to the order desk where I was then assisted by a, you guessed it, English speaking person. No run around whatsoever. I gave them the serial number and they gave me what I needed. I had the parts in my hand in 4 days. I had to pay for the gaskets since the warranty is long expired, but I don't care about that. I care that when that compressor is down, my work flow screeches to a stop. They got me back online ASAP. In this day of off shore crap with no backing by the manufacturer, it was a very welcome relief and it made me a very loyal customer to IR. You're not going to get that kind of service from a Campbell Housefield or similar offshore brand.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 05-25-2009 at 10:18 PM. |
